Cylinder one code on the obdII
Old Dec 17, 2013 | 02:32 PM
Willyb's Avatar
Default Cylinder one code on the obdII
Cylinder one misfire code on 2006 jaguar s-type 3.0 53,000 miles. Should i replace the coil and spark. Car runs fine but it came on after, i punched it last night. I stopped the car and shut it down, it went into performance shutdown mode. When I started the car back up it was fine but the check engine light was still on, of course. The car has run fine today but, i am still a little nervous about it. I have been some what gentle with it.
Old Dec 17, 2013 | 02:41 PM
Always best to post the actual codes rather than descriptions.
For a misfire, I usually swap coil positions and see if the code changes to the new location code before assuming a defective coil.
Old Dec 17, 2013 | 02:53 PM
tbird6's Avatar
Good advice!
Swap the coil and post the actual code.
It does help.
Old Dec 17, 2013 | 03:51 PM
Number one is under the manifold so replacement might be worth thinking about after a bit more investigation.
Bcrary3
Sep 12, 2021 05:41 AM
KarimPA
Sep 27, 2015 08:46 AM
Jagged-X
Sep 24, 2015 05:08 PM
tsimms7
Sep 15, 2015 12:43 PM
Bcrary3
Sep 11, 2015 10:36 AM
