dead battery 2000 s type v6
Old Jul 29, 2013 | 01:47 PM
Bruce Stevens's Avatar
Default dead battery 2000 s type v6
I have a problem with the battery going dead every couple of days. I have traced it to the radio/cd player. I have pulled those fuses and the problem has stopped. The radio worked, until I pulled the fuses. I was told that this is common and it is probably a defective amplifier located between the two rear speakers on the rear deck drawing current when the ignition is off. Does this sound right ?
Thanks, Bruce
Old Jul 29, 2013 | 01:52 PM
Bruce,
I've moved your question from General Tech Help section to S-Type section. This could be a 'feature' (!) of the S-Type and members here with the same model will be able to advise.
Old Jul 29, 2013 | 02:00 PM
JagV8's Avatar
I'd say extremely uncommon. If you're sure you've traced it to a fuse that only covers what you say then you have a virtually unique problem, seems to me, but hey stuff happens.
Fair chance you can get used parts cheaply and swap them.
Old Jul 29, 2013 | 02:04 PM
sjgh's Avatar
You sure you don't have a cd spinning in the tray? Used to happen on my daughters Volvo S80 - battery was running dry every so often - took the cd out and all was well.
Old Jul 30, 2013 | 10:28 AM
police666's Avatar
put the fuses back in and unplug the rear amp, access via trunk, and see if you still have a drain, then you will know if it is the amp or not before spending money.
A few common battery drain problems are, lights in the boot staying on and the little flap not closing on the ignition barrel.
MJ'S Jag
Nov 10, 2022 08:14 AM
Thia
Sep 1, 2015 10:36 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
