Defeat/uninstall PATS
Old Aug 17, 2025 | 03:01 PM
hak's Avatar
hak
Default Defeat/uninstall PATS
2001 Jaguar S-Type 4L 53k miles. I've had problems with the PATS for 2 years where it will not start and will cut the engine off when driving. The fuel pump is disables. The security light blinks the 16 code when this happens. I am done with trying to find the problem and want to defeat/uninstall/bypass this system.
Has anyone on the Form has any success in getting rid of system?
Thanks for your help,
Howard
Old Aug 17, 2025 | 03:12 PM
motorcarman's Avatar
PCM verify does not match key status.
Try one of your other keys?
File Type: pdf
Old Aug 17, 2025 | 03:46 PM
hak's Avatar
hak
Both keys have the same problem. I think it is either the SCP or a faulty antenna ring, and I am tired of trying to find the root cause. Everything will work good for a month and then the PATS will act up.
Old Aug 18, 2025 | 06:29 AM
JagV8's Avatar
Only way to get rid of it is to get rid of the car.
Otherwise, fix it.
Old Aug 18, 2025 | 10:20 AM
xalty's Avatar
pats light is blinking because the scp link is down it doesn’t shut down the car. you need to use your brain cells and see what’s a no-comm when it fails
hak
Oct 26, 2024 06:28 AM
daro31
Feb 17, 2017 05:10 AM
pilotmanitalia
May 9, 2014 02:24 PM
Mack
Jan 2, 2012 09:50 AM
