Dexron III Power Steering Fluid Source
Old Apr 27, 2019 | 10:28 AM
kr98664's Avatar
Default Dexron III Power Steering Fluid Source
Greetings,
Can somebody please guide me to an easily obtainable source of power steering fluid for my '02? The service manual simply calls out Dexron III. No problem, I thought, but I managed to stump an experienced counterman at my local parts store.
Do I just use straight Dexron III transmission fluid? Or should I find a power steering fluid that meets the Dexron III standard? There was a bewildering variety of power steering fluid on the shelf locally, but we couldn't find anything on any bottle verifying it met the Dexron III standard. And what of superseded standards? Does Dexron IV or V also cover III? My head was spinning after a few minutes.
I'd appreciate any tips, such as "Valvoline product #ABC123", etc. Preferably something I can find locally at most any parts store.
Thanks.
Old Apr 27, 2019 | 11:09 AM
S-Type Owner's Avatar
From "It still runs":
GM terminated all licensing for the production of Dexron III in 2006. The company advised GM vehicle owners that any other manufacturer's claims made of compatibility past 2006 without official GM endorsement would be inaccurate. GM informed the public that the only fluid compatible with Dexron III was the replacement Dexron VI. The automaker then authorized licensing of Dexron VI; GM publishes a list of companies and product names that comply with its specifications for the fluid...
Old Apr 27, 2019 | 12:55 PM
Doug's Avatar
Any of the later iterations of Dexron should work OK as a replacement for Dexron III; they are backwards compatible.
That said......
I'm not sure how critical this would be for use in a power steering system. All five of my 1995-older Jags have specified Dexron as power steering fluid and, truthfully, I've just used whatever bottle of ATF was easiest to reach at the moment. Nothing bad has happened.
But, my level of nonchalance in this regard might not be appropriate for a newer Jag.....nor comfortable to some owners.
Old Apr 27, 2019 | 05:41 PM
kr98664's Avatar
What about this? I’ve got several quarts of NAPA premium ATF in the garage. The label says it’s applicable for Dexron III (in a transmission):
Old Apr 27, 2019 | 06:11 PM
Doug's Avatar
Looks good to me; I'd use it
Old Apr 27, 2019 | 08:31 PM
joycesjag's Avatar
Me too!
Old Apr 27, 2019 | 09:08 PM
Me too.
Old Apr 28, 2019 | 02:54 PM
abonano's Avatar
Yes, good to go
Old Apr 28, 2019 | 03:55 PM
CThomas's Avatar
Default Advance Auto Parts has this
This is from Advance Auto Parts.
Old Apr 28, 2019 | 07:36 PM
wydopnthrtl's Avatar
Here is what I used --> https://www.jaguarforums.com/forum/s...vation-209156/
penguin
19
Jul 20, 2023 12:54 PM
orangeblossom
Sep 22, 2017 12:19 PM
michaem101
Jan 9, 2017 05:35 PM
BKSinAZ
Feb 21, 2015 02:02 AM
