Diagnostics Are Good! DCCV looks good. Still no heat... Help me out!
  #101
Old 03-28-2011, 07:39 AM
monteroz1's Avatar
Hey guys . I have learned much on Jaguar xk8 so this is what may be problem. Had no heat then replace heater control valve, which may or may not have been bad. Still no heat. Then mechanic said it might be auxillary pump, which is also expensive. It was the problem. Mechanic wanted to put on new one but I told him to take it off I took it to my electrical shop (40 years rebuilds on alternators and stuff that has motors) Had Auxiliary pump rebuilt for $50 and mechanic put it back on and now I have heat So please if you have auxillary pump. Try that . He ruled on CCV
monteroz
1998 jaguar xk8 w arden kit
2008 victory kingpin 8 ball blacked out cycle
  #102
Old 04-19-2011, 05:45 PM
wordman's Avatar
BugDog...going to back flush my 2003 S 4.2...just to clarify...I am sending water from my garden house through the line at the connection to the radiator overflow and then disconnecting the bottom line closest to the ground to release water and debris. The bottom line is warm while the other two lines are hot...my driver side heat is luke warm and takes 15-20 minutes to produce heat. passenger heats works well. thaskn john
  #103
Old 04-21-2011, 09:24 AM
monteroz1's Avatar
Well it is tone to rebuild aux pump. Think they cost 200 plus or more but I can't remember . If you aux pump is seized dong but new take Yo ant alt/ generator bebuildet and get rebuilt. I can get rebuilt for you or you can ship to Marietta auto electric . Paid on 50 for rebuild. Done know what you will be charged but they do a lot of business w me on vehicles alternator. Inc jag alternator . Call me 404 431 3875
  #104
Old 04-21-2011, 10:06 AM
Gus's Avatar
Gus
Gus is offline
Received 2,209 Likes on 1,701 Posts
I hesitated bring up the heater aux pump in the search for this problem because the 3.0 does not have the pump but the V8 does. Rebuilding the pump is a little time consuming but can be done. I took my pump apart on my 95 xj6 and it was a matter of just cleaning the pump action. This a link to the pump XJ6 Heater Pump Repair Now I have been told that replacing the brushes on the armature is not difficult. Brushes can be purchased at your local RadioShack but not an exact fit you will need to shave or sand down to fit.
  #105
Old 04-21-2011, 11:18 AM
highonpsi's Avatar
Have you found what the problem was? I have an 03 s type r with the same problem, no heat, but AC is fine.
  #106
Old 04-21-2011, 12:46 PM
Gus's Avatar
Gus
Gus is offline
I found it to be the problem in my 95 xj6 when i had it. Turn the heat on and see if the pump is working by putting your hand on it.
  #107
Old 05-26-2011, 01:39 AM
ndy4eva's Avatar
I do have same problem as well. How did you guys repair it? Was it simple "Evaporator Discharge Temperature sensors" failures?
I do have A/C and Heat on Lo and HI, just it doesn't seem to blow right temperature air (usually colder air).
  #108
Old 12-11-2011, 04:21 PM
cliff's '00 3.0 s-type's Avatar
Default same problem no heat
Originally Posted by BugDoc
Once the engine cooled down, I went back out and plugged in the DCCV electrical socket. Then I started the engine and let it run for a little while.
With the Dash controls set to low temp (<65oF), the two top hoses - pipes- remained cool.
That is the two marked with the yellow arrows. The lower hose was VERY hot. About the same temp as they all were when the electrical connector was disconnected.
So, I am pretty convenced that the DCCV is working correctly. Do you agree?
I crawled under the dash on the passenger side and I located the blower fan. I cannot seem to find the mixer flap/door control.
Any help on that? I searched for pics but only came up with three threads. This one and two others. Please give me some tips! Thanks.
I have the same problem, no heat. When I let the car warm up to operating temp. all three pipes that you had pictured remain cool when the heater is set to high. I also noticed that the hose under the thermostat remained cool. Would you think my problem is a faulty thermostat? Any help would be appreciated.
  #109
Old 12-11-2011, 05:31 PM
JagV8's Avatar
Received 4,497 Likes on 3,912 Posts
I suggest you stop posting the same question all over the forum. It's the sort of thing that just occasionally gets a member banned.
  #110
Old 04-27-2013, 04:50 PM
chtp66's Avatar
BugDoc,
Did you ever figure this out and find the issue? I have a 2003 S-Type and suspect the blender door actuator is faulty. Interested if you ever found it.
  #111
Old 04-28-2013, 01:10 PM
wordman's Avatar
Smile
DCCV and CCM... Just my experience with my S 2003 JAG 4.2. over a year messing around...replaced the DCCV then finally got mine rebuilt CCM for $250 I think...Everything worked perfect after that. wordman
D.K
12-10-2023 02:05 AM
02jagstype
23
10-23-2022 07:03 PM
way2far
08-31-2022 09:26 AM
Rivguy
12-04-2020 07:55 AM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: Diagnostics Are Good! DCCV looks good. Still no heat... Help me out!
