disable Drive Away door locking
Old Nov 19, 2018 | 06:22 PM
ian.fox's Avatar
Default disable Drive Away door locking
Is it possible to cancel the drive away door locking 'feature' without dealer intervention? 2002 model.
cheers
ian
Old Nov 20, 2018 | 01:37 AM
Datsports's Avatar
yes , but you still need the dealer tools . you can download the software and buy an interface if you like , but its not cheep.
you could look for a jaguar independent near you ?
Old Nov 23, 2018 | 05:13 AM
dopey's Avatar
If you don't mind a drive to Laverton, Victoria it can be done!
Old Nov 23, 2018 | 06:02 AM
M-e-l-l-o-w's Avatar
Try the following.
This may work to deactivate the auto locking:
Turn on the ignition so all the dash lights come on but do not start the engine.
Lock the door using the button on the door handle and then unlock the door 3 times. (But do not open the door.)
Turn off the ignition.
Turn on the ignition but do not start the engine and you should hear a beep.
Lock the door then unlock it, once only this time, and you should hear a final beep.
The feature should remain deactivated until you repeat the procedure above to reactivate it again.
Do let us know how you get on.
Mellow
Old Nov 23, 2018 | 06:00 PM
ian.fox's Avatar
Originally Posted by M-e-l-l-o-w
Try the following.
Mellow
Couldn't get it to beep unfortunately :-(
toshy
Aug 4, 2014 10:07 AM
v6jon
Mar 10, 2014 01:10 AM
JAG_XJ
Nov 22, 2013 12:05 PM
MartinP40
Jul 23, 2013 01:32 AM
DawgsXtype
Aug 17, 2012 02:48 PM
