Disconnected battery and windows won't...
Old Jan 26, 2009 | 01:14 PM
donnic's Avatar
Default Disconnected battery and windows won't...
I disconnected the battery to install air intake system and now the windows will not roll up automatically on the one touch. They will roll down on the one touch but not back up unless I hold the window up button down. Any suggestions? I'm thinking a fuse but not sure. I only disconnected the battery on the negative side and when I reconnected it, it sparked quite a few times. Everything else seems to be fine except for the one touch roll up on the windows.
Old Jan 26, 2009 | 01:15 PM
donnic's Avatar
Default RE: Disconnected battery and windows won't...
oh yeah, i have an '03 s-type v8 model.
Old Jan 26, 2009 | 01:20 PM
Real_Tech's Avatar
Turn key on or start engine, run windows all the way up, hold each window button in the up position until you hear a click in the door, helps to have the radio and climate fan off. they just need to be reset.
Old Jan 26, 2009 | 01:34 PM
donnic's Avatar
Thanks Real_Tech, that worked perfectly.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
DuhCar
Sep 11, 2015 10:58 AM
