Does disconnecting battery reset transmission module
Old Jul 28, 2012 | 12:16 PM
coolhotblue's Avatar
Default Does disconnecting battery reset transmission module
just had my transmission fluid flushed / service at an independent jag service shop. trans is shifting like butter now....still have a slight metal grind as if searching for a gear under low load at 45-55mph???? (rear diff, bearing???)but overall the shifts are much smoother, no more lurch and much better driveability, for anyone debating on a trans fluid service, mechanic said "just bite the bullet" and get it done, im at 66000 miles and he said my fluid level was low and fluid was dirty.....the question however is...will disconnecting and reconnecting my battery act the same as a flash from the dealer???
Old Jul 28, 2012 | 02:58 PM
tony1963's Avatar
Nope.
Old Jul 28, 2012 | 03:25 PM
Brutal's Avatar
Ditto
Old Jul 28, 2012 | 03:33 PM
Wow thanks for the reply..... its official, i wont be disconnecting the battery anytime soon.... Brutal said so and thanks to tony1963 as well...Brutal if you can help me out...how about that metal grind noise at 45-55mph?? any ideas?/
Old Jul 28, 2012 | 07:55 PM
tony1963's Avatar
Differential failure
Old Jul 28, 2012 | 10:12 PM
Brutal's Avatar
wheel bearings, diff, beer cans still tied to bumper from your wedding day............need to go in the air and spin to this speed and listen with a stethoscope
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
