As donor car for engige swap questions
Old Feb 2, 2022 | 06:28 AM
killerbee's Avatar
Default As donor car for engige swap questions
Hi
I am new to Jaguar so but not new to engne swaps . I get one classic ford without engine and seach for good V6 , then found that s-type cars are lot cheaper than ford engine . So I can get Stype 3.0 manual in running condition . My questions are : Can the engine work with stock ecu and harness or easier to put aftermarket ecu , if yes which modules I need . And other question is can I use the climate system as stand alone system and also what modules i need to get it running .
Thanks in advance
Old Feb 2, 2022 | 09:41 AM
S-Type Owner's Avatar
Classic FORD leaves a lot of room to maneuver; to some an unexploded Pinto might be a 'classic'...
That said, 3.0, V6 conversions are popular with some early Mazda Miata enthusiasts; I believe they tend to favor stand-alone engine management systems, You might want to begin you search there...
Old Feb 2, 2022 | 09:46 AM
killerbee's Avatar
I've read most of miata and locost posts and if they use aj30 they use standalone , ford mondeo engine is more simple to use with stock . It is not a problem to run this engine with ecumaste or similar but prefer stock . Climate condition is more problematic to me and do not know if I will be able to use ... so that is why I join this forum .
Old Feb 10, 2022 | 09:41 AM
elDariusVargas's Avatar
I did an aj30 swap myself.
what car are you going to install it in?
Old Feb 10, 2022 | 09:43 AM
killerbee's Avatar
1965 ford taunus ..
What car did you swap in ? Please post me mote info what do I need from the jaguar
Old Feb 10, 2022 | 10:35 AM
Originally Posted by killerbee
1965 ford taunus ..
i did it in my s type since ive had the 2.5l and
burned its gaskets.
but you're doing it on a different car so youll have to do some research and pick which engine accessories you will be using.
a standalone might give you easier and faster control. Less errors
There are lots of swaps done using this engine.
Old Feb 10, 2022 | 08:24 PM
xalty's Avatar
is this the aj60 (up to 2002) or aj62 (2002.5 and later)
these engines are very different
Old Feb 11, 2022 | 02:47 AM
Sorry for replying twice
killerbee i see you're from
bulgaria, and since you aint got no engine size taxes, why dont you throw a v8 in there from an old ford or 2000 s type (4.0)?
Someone even did a lexus v8 swap. And that one runs perfect. Check your dm
if tou can fine a LS from a corvette that would be a dream, but i bet huge costs implied
elDariusVargas
Jan 3, 2022 05:13 AM
elDariusVargas
Jan 2, 2022 06:22 PM
Mikedarija1
Apr 27, 2019 10:18 AM
jagvlo
Sep 12, 2018 07:32 AM
nahum
Nov 21, 2015 11:02 AM
