driver seat/steering pre-programmed setup
Old Sep 15, 2022 | 04:29 AM
Rober2's Avatar
Default driver seat/steering pre-programmed setup
Hi,
Coming back from the shop, the driver's seat and steering wheel seem to have lost their settings.
  • turning the ignition off and taking out the key does not pull the seat back or raise the steering
  • with the key off; I can raise the steering using the control and pull the seat back with the seat control
  • putting in the key does not adjust the seat or steering to any of the memory settings
  • Using the 1 or 2 buttons will set the config to saved setting
How do I reset the config as normal? I can bring it back to the shop, but I would like to know if there is a way to recalibrate or reconfigure it. Thanks
Old Sep 15, 2022 | 08:01 AM
S-Type Owner's Avatar
Typically, if the battery has been disconnected for any period of time, settings such as seat/steering wheel, etc., will be lost. I cannot speak for the early version, but on my 2003, you place the seat, steering wheel, etc., in the desired position and with the ignition turned on, press "memory + 1 or 2"; the instrument cluster info screen will then confirm that the positions were saved.
This should be in your owner's manual.
Old Sep 15, 2022 | 09:11 AM
motorcarman's Avatar
Jaguar addressed many issues with TSBs.
You should probably find and read all related to your car.
Lots of questions answered and features you may not know exist?
File Type: pdf
Old Sep 15, 2022 | 04:39 PM
Rober2's Avatar
Memory + 1 or 2 works. It saves it and returns to the setting when I push any of them. The one I would like to fix is when I take the key out, the seat no longer pulls back and the steering wheel do not raise.
Old Sep 15, 2022 | 04:46 PM
Rober2's Avatar
Thank you, I may have found the answer from the TSB link you gave. Cheers
Old Sep 16, 2022 | 02:36 AM
Rober2's Avatar
got it. the shop set the steering control to 'off'. all I did was turn it to 'auto'. its all good. thanks
Metalart
XF (X260)
Aug 12, 2019 10:59 PM
cjag05
Jul 4, 2013 02:25 AM
user 2029223
Feb 1, 2010 12:25 PM
jhh
Oct 31, 2009 05:11 PM
rgzx11
Jul 29, 2008 03:06 AM
