DSC,ABS disabled Parking brake fault...
  #41
Old 07-08-2011, 12:59 PM
tbird6's Avatar
Great news but can you explain how the problem was found? I would have never found that!!!
  #42
Old 07-09-2011, 02:36 AM
Cadillac's Avatar
Good to see you found the smoking gun , I think troubleshooting an A/C should be as hard as diagnosing an elusive leak for coolant system
  #43
Old 07-09-2011, 09:35 AM
kaine806's Avatar
The problem was found with luck...lol
I needed to replace the PS DCCV valve. it was stuck on cooling. so the PS had no heat in the winter..
and after I replaced it the heat was still not working. and after doing a little searching on that I found that those valve's can take out the A/C control module some how.
I was able to find one in a junk yard that was in real good condition so I removed to old one. while I was waiting on the other one to get here.. and i was kinda supprized that the car would run with out it.
So I hooked my laptop and the only code's being displayed at that time was every single code for the A/C... then after installing the new A/C module I did a hard reset on all system's then fired it up.. checked the heat and A/C out and both are working good now.
I let the car run to warm up completely and I ended up letting it run for about 2 hours waiting for the code's but it never did it when before it would take about 30 to 45 minutes and it would cut out..
and since then I have put about 1200 miles on the car and it is still running strong..
last saturday we took it down to Balmorhea,TX... about 260 miles one way from lubbock..
But honestly if I had not had a bad DCCV valve I probably would have never found it eather...
  #44
Old 07-09-2011, 09:53 AM
Gus's Avatar
Gus
Gus is offline
Received 2,209 Likes on 1,701 Posts
You did a great job in troubleshooting and I am not sure I would have had the patience. Kudos to you! On the road again!
  #45
Old 07-10-2011, 08:33 AM
snoozdaddie's Avatar
Default I have the same problem
How did you resolve your issue ?
  #46
Old 07-10-2011, 09:32 AM
JagV8's Avatar
Received 4,489 Likes on 3,906 Posts
Er... read the thread.
Even better, read the other similar threads on here as well.
  #47
Old 07-11-2011, 06:27 AM
The Chris X's Avatar
LOL - heck the answer is 2 posts up from this question!
Nice work troubleshooting Kaine! Glad to hear you got it going.
  #48
Old 07-12-2011, 06:20 PM
kaine806's Avatar
It was a pain the but first off...
after doing my research on the issue. I found that any module in the car can cause it do this. and also any wire connection in the communication loop in the car can cause this as well..
Down load JTIS you can find it in the forums and find get the plug locations and wiring diagrams for your make and model.
Go through them all and make sure there all in good shape and clean any dirt or water out of them.. The issue with mine turned out to be the A/C control module.
It took me about 6 weeks to luck into fixing the problem.
  #49
Old 09-08-2011, 01:14 PM
esipp's Avatar
currently having same issues with my 2004 s-type. on another thread, I read: check the wiring on throttle body (clean, disconnect and reconnect several times) and cleaned the throttle body. so far codes have not reappeared after 100 miles...solution seems to work for now.
  #50
Old 09-09-2011, 03:59 AM
Default Same result
After doing the same on my "S" as well, the codes never came back..
Good luck !
  #51
Old 09-09-2011, 08:23 AM
bertrandgray's Avatar
Congrats on finding the problem! As a fellow jaggernaut that has been bitten (an almost eaten) by the dreaded limpus modicus virus, I continue to be amazed about the variety of unrelated problems that can throw this car into limp mode. The only thing more amazing is the lack of experience Jag dealer techs have in diagnosing the real problem when it is outside of the standard throttle body, MAF, gas pedal, and battery scenarios.
Good job.
  #52
Old 09-10-2011, 01:38 PM
esipp's Avatar
The soution only cost ne maybe 20 min of time & $6 for the cleaner- very cheap resolution!
PMKimpton
08-03-2019 08:22 PM
neruda
10-18-2015 01:19 PM
Nigels420G
Mark V - X 420G
09-17-2015 10:29 AM
sawduster
09-11-2015 10:02 PM
Quick Reply: DSC,ABS disabled Parking brake fault...
