DSC Light flashing
Old Jan 14, 2010 | 06:41 AM
edhowey's Avatar
Originally Posted by jagv8
You still didn't post your VIN. The TACM may not exist in your car. Also, if your DSC now needs calibrating you must have a fault, such as wiring, to explain why it needs that. You may well find you can't get data using AE so try it. If you can't it helps you figure out which wires are damaged.
You can read the yaw etc sensors using AE so again you can check.
I will look at the VIN and post it when I get home this afternoon. There were serveral DSC codes set when I first hooked up the AE, I think they were never cleared by the dealer following repairs from the deer strike. Damage area was right front (extensive damage $11,000.00). These codes have not come back but when I cleared them with AE the DSC began flashing. I am going to check the harness in great detail this afternoon. I plan to completly disconnect the engine harness and check ohm readings pin to pin as well as physical check(looking for the cause of P1584). I am convinced now that the DSC flashing just needs to be reflashed. I have a service appointment with the dealer next Tuesday to reflash the DSC. I will post results of the harness check late tonight. If I do not find anything with the harness I am just going to bite the bullit and replace the APS.AE reads all ABS/DSC sensors and they appear to be responding properly. There is one strange reading, the steering position sensor shows an angle of -27 deg when going straight ahead. Wheel is centered. I hope that recalibration will correct this. Is it possible that I got the sensor out of position when I had the dash out to replace the AC evaporator?
Thanks for the help.
Old Jan 14, 2010 | 08:57 AM
JagV8's Avatar
The steering angle is probably OK. I think they read some value (which looks pretty random) and that is then programmed into the module when it's configured. You could say that it'll be set so -27 is straight ahead and thus other values can be figured out relative to that datum.
I really can't see why your module would need reflashing
(Can't hurt to try - apart from maybe your wallet.)
Old Jul 21, 2014 | 06:23 AM
Texascherokee's Avatar
Default 2000 s type 4.o DSC light flashing
Code says the sensor in the steering wheel ? Will A alignment change this and turn off the light? Got car running been setting for four months. Was A bad computer. I would like to see if I need the sensor or A Alignment car had bump in front driver side. Anyway would like to have my Cruze working.
RonnieJoe
Dec 24, 2020 03:51 PM
redrover41
23
Sep 25, 2015 01:33 PM
mrplow58
Sep 9, 2015 11:27 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
Mosers63
Sep 6, 2015 02:53 PM
