Electrical Problem Inconsistent
Old Apr 19, 2016 | 09:50 AM
Chefsrus05's Avatar
Default Electrical Problem Inconsistent
After many hours & Days searching the posts on the website. I couldn't find the answers im looking for. I have been experiencing strange electrical problems. It started with, when headlights are on radio controls on wheel being tricky. From there I started getting different dash lights like low oil, Brake on, then headlights wouldn't shut off, also they would turn off while on the road, alarm stopped arming, High beams didn't work, Car would be hard to steer, horn wouldn't work, inside dash lights wouldn't work.
There may be a few things I missed. But everyday is like a pot luck, I wont know whats going to work or not work. Very Stressful. I had my alternator Battery and starter checked out. During this time I never had to jump the car. Help Please
Old Apr 19, 2016 | 10:08 AM
Jon89's Avatar
Sometimes faulty and dying batteries still test good. The battery is ALWAYS the first suspect in cases such as yours....
Old Apr 19, 2016 | 12:13 PM
Chefsrus05's Avatar
jon89 My battery is less than a year old. Where would you look next ?
Old Apr 19, 2016 | 01:43 PM
Jon89's Avatar
Battery age does not matter. Some batteries are faulty right off the store shelf. Yours may have a bad cell. Who tested it, and how?
Old Apr 19, 2016 | 02:24 PM
Chefsrus05's Avatar
auto zone did a test with the car off and on. with a load and without
Old Apr 19, 2016 | 08:19 PM
Ragn0r's Avatar
This product is always in my boot for ensuring good electrical connections. One tip that may be helpful is to remove fuse rotate it 180 degrees and put it back in place. Flipping the fuses causes a fresh connection. Refresh the battery earth connection at the frame.
Electrical Contact Lubricant - Conductive Electrical Grease | Sanchem, Inc.
Old Apr 21, 2016 | 08:50 AM
JagV8's Avatar
I think heavy brakes would be a vacuum leak but the others sound like power/ground/battery faults.
Work through the workshop manual on power/ground/etc. Maybe grab some sort of voltage/power monitor, hook it up to each circuit in turn, and see if it helps.
For any more help please add your car details!
Old Apr 22, 2016 | 09:50 AM
Chefsrus05's Avatar
thank you all for the input. I was squeezing connections to the gecm and heard a click. thank god that was it. the connection is down where my feet are and im a tall guy must have kicked it loose.
XJR100orXKR100
Apr 4, 2016 11:42 AM
robearner
Apr 2, 2016 03:51 PM
XXCalibar
Mar 29, 2016 05:20 PM
DEklof
Mar 28, 2016 12:07 PM
DanielSWE
Mar 28, 2016 06:22 AM
