Engine Shudders
Old Jul 6, 2016 | 06:54 PM
JagDiva's Avatar
Default Engine Shudders
I have a 2000 Jag S type 4.0.
I have recently noticed that the engine shudders and hiccups when I go up a hill.
Also notice that sometimes when on idle waiting for the traffic light to change, it trembles.
Has anyone had these problems before or know what could be wrong?
Thanks in advance for your feedback.
Old Jul 6, 2016 | 07:44 PM
Mikey's Avatar
Is the check engine light on? Are there any codes?
Old Jul 6, 2016 | 08:33 PM
JagDiva's Avatar
Default Engine shudders
Hi Mikey
No check engine lights or other warning lights come on.
The car oil is changed every 3K miles although I did go to a local mechanic the last 3 oil changes. They used synthetic blend oil which they say was better.
My car has 95,000 miles on it.
Old Jul 6, 2016 | 08:40 PM
Mikey's Avatar
Did you check with an OBDII reader for any stored codes? Have the cam chain tensioners been upgraded to the latest standard?
BTW- your car does not need or benefit from 3K oil changes, or synthetic oil. You're wasting money. The factory recommended interval is 10K miles or annually, using standard oil.
Old Jul 7, 2016 | 01:25 AM
JagV8's Avatar
Sounds like an air leak or misfires. Check OBD for pending codes a few times and of course check fuel trims.
Old Jul 7, 2016 | 04:19 PM
JagDiva's Avatar
Hi Mikey,
How do I check the OBDII codes myself? I know nothing about cars, but would be able to figure things out as I'm technically inclined. Do I need equipment? Or is this something I have to take to a mechanic?
Old Jul 7, 2016 | 05:21 PM
JagV8's Avatar
Search and google will get you info.
Old Jul 8, 2016 | 09:40 AM
Mikey's Avatar
If you're not familiar with diagnostics and repair on moderns cars, best off finding a trusted local mechanic to at least read the codes for you. Give us the numbers they find (not the names on his reader display screen). It usually has the form of one letter and four digits.
Old Jul 8, 2016 | 01:00 PM
joycesjag's Avatar
Fuel filter?
mikechinea
Apr 16, 2017 05:27 PM
Lawrence
XJ40 ( XJ81 )
Apr 23, 2016 04:27 PM
xjmaz
Diesel variants - All models
Mar 27, 2016 02:53 AM
scchuck
Sep 18, 2006 07:53 PM
Aug 5, 2005 11:01 PM
