Exhaust Tips - Cleaning
Old Jun 7, 2007 | 08:45 PM
sempaipaul's Avatar
Default RE: Exhaust Tips - Cleaning
Ok..I am a part-time detailer at a shop... so..
1. Take a peice of steel wook
2. Put some wheel cleaner on it
3. rub in vigorously
4. use wax and wax it.. take wax of... and you got new tips!!
Paul
seviz@aol.com
Old Jun 7, 2007 | 10:15 PM
racerx82's Avatar
I just use stainless steel cleaner.
Old Jun 8, 2007 | 09:52 AM
JagStypeR's Avatar
ORIGINAL: racerx82
Same here, not sure I would use "steel wool" [sm=yikesomg.gif]
Old Jun 8, 2007 | 05:54 PM
Envy337's Avatar
Best stuff i ever used was a chrome cleaner made by the same company that makes Turtle Wax
Old Jun 9, 2007 | 01:45 AM
04Xtype's Avatar
i havent cleaned my tips since the day i got the car, i think once i get it back from the shop, itll be the first thing i do
Old Jun 9, 2007 | 09:43 AM
badmojo's Avatar
I use Mothers Metal Polish on my stainless tips and it works great!
Old Mar 10, 2010 | 10:03 AM
d33's Avatar
d33
How ofter do you guys have to clean your tips? It seems after a few days (3-5) mine are black again, well the bottom part. I find that kind of fast, considering I don't beat the car up.
Old Mar 10, 2010 | 11:33 AM
joycesjag's Avatar
Our SS tips are clear coated, I use the "metal polish wadding" which is wool soaked with kerosene basically. I wipe Joyces down as needed 2/3 days. I also keep the Jaguar code of ethics... Never let a Jaguar be "dirty"!
Old Mar 10, 2010 | 11:45 AM
Jon89's Avatar
With previous vehicles, I've crammed tennis ***** into the exhaust pipes and then hit the tips with a 3,000 psi pressure washer when I've already had it out for washing the house or the driveway and front sidewalk or the back deck. I won't drag out and fire up the pressure washer just for doing exhaust tips, though....
Old Mar 10, 2010 | 11:29 PM
androulakis's Avatar
OK so how do you suggest I approach a car where the tips don't even appear to be stainless anymore but rather a dull grey metal.
This is a northeast car that has seen tons of road salt in the winter etc... I got it for a song at the dealer auction (via a good friend), and have been slowly fixing it up. Now that the weather is nice I want to focus some attention to detailing.
I honesty was considering getting the tips replaced with something new. But I'd be willing to try anything.
George
Old Mar 10, 2010 | 11:54 PM
ccc's Avatar
ccc
The advise that I got from a high-end detailer that does quite a number of exotics:
Zymol Metal Britework Polish ($30 for 4 wipes) or 0000 or 000 steel wool with water or quick detailer as a lube. Not wanting to pay $8 per pop, I've have been using the 000 wool on the brushed SS pipes on my STR and the chrome tips on the other cars for years without any signs of wear.
Old Mar 11, 2010 | 06:12 AM
joycesjag's Avatar
George, I have found most of the chrome or SS has been either clear coated or anodized. You can try a yellow can of Easy Off oven cleaner. Warm the tips up by running motor 2/3 minutes, spray only the tips, using blue masking tape tape off surrounding area, wipe down with 000 steel wool. Wear rubber gloves, due to the caustic acids! May take a couple of tries. The oven cleaner will remove any anodizing or clear coat. Polish with SS cleaner.
Old Mar 11, 2010 | 08:40 AM
Delta66's Avatar
I used Brasso and a cloth since the chrome is slightly perished, so nothing more vigourous than that. The rest of the time saop and water when the rest of the car is being cleaned.
Old Mar 11, 2010 | 11:25 AM
Stainless steel tips here....From day one, anytime the car is washed the tips are too...after all they are part of the vehicle. TheN again I always do the door shuts, boot and bonnet and under the bonnet too. Really doesn't take that long!
As for cleaning them when really bad? Try very fine steel wool / brillo pad coupled with plenty of elbow grease. Once the worst is off I use Autosol metal polish with some 800 grit wet n dry and just keep going over n over them until extra shiny. Once you've got them there you can wax them I guess, although as I wash mine EVERY time the car is washed they really don't need it IMO.
Old Mar 11, 2010 | 12:29 PM
fergs03R's Avatar
+1...sold at autozone for 10 bucks and it works amazing
Old Mar 11, 2010 | 03:40 PM
styper526's Avatar
I have been afraid to use steel wool on my mina exhaust so I strictly use never-dull. it's much like whats described in an earlier post, basically wadding soaked in a kerosene based cleaner. it takes some time and elbow grease if you are not on top of polishing them up at each wash!
Old Mar 17, 2010 | 02:43 PM
Crazee Horse's Avatar
I use Peek polish. It works well on stainless and brushed aluminum. I use Mothers for chrome. It works well just stay on top of it. For a first time clean I have used hand rubbing compound.
Old Mar 17, 2010 | 05:02 PM
mep's Avatar
mep
Originally Posted by Delta66
I used Brasso
+1 That's what i use as well.
Old Mar 18, 2010 | 08:06 AM
cacloss's Avatar
Great on chrome tips!
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
jaaag
Sep 11, 2015 12:53 AM
