Fail safe
It's protecting itself (well, you) from a disaster.
It may not be able to flag codes, depending on how much is wrong - e.g. it needs to know a lot works in order to home in on the real problem.
You may have pending codes. (You will definitely have P1111 or P1000 - which?)
You may have unset OBD monitors - check and if so then each suppresses a lot of codes.
OBD live data might reveal some wacky value - worth looking.
You know the 4.0 can have issues with tensioners & have checked your is OK / replaced them? See existing threads...
JeffereyGreen
May 3, 2011 07:27 PM
