false rear light warning
Old Apr 24, 2013 | 03:47 AM
thommo's Avatar
Default false rear light warning
I have been getting warning messages about right rear light or right brake light. But the bulb works and replacing it didnt help. What is going on? Has anyone any ideas?
Old Apr 24, 2013 | 05:58 AM
jimgoose's Avatar
Mmmm. Very occasionally I get "Right brake lamp failed" and, lately, "Left repeater failed". They both go away again fairly quickly, and everything seems fine. It isn't annoying enough to prompt me to do a thorough investigation, though.
Old Apr 24, 2013 | 06:33 AM
JagV8's Avatar
Loose contact, damaged wiring, poor connector, just get busy with a meter when it's failing.
Old Apr 24, 2013 | 08:51 AM
Jon89's Avatar
Pull the bulb, clean and burnish the socket, replace the bulb, check for tight fit. That fixed our similar issue back in 2009. No similar problems since....
You have already checked to see that you are using the correct replacement bulb - right?
Old Apr 26, 2013 | 04:20 AM
thommo's Avatar
Thanks for the tips, its ok now with a new bulb and a cleanup. Strangely the warning light gave one more warning before it went out so I wonder if it waits to see before forgetting about a problem.
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
