fans full speed and overheating
Old May 9, 2012 | 07:06 PM
slideshow801's Avatar
Default fans full speed and overheating
so still having the over heating problem. ive put new thermostat (from ford) and new reservoir cap .
takes about 20 mintues of idling then fans slowly creep up speed then eventually go full blast after full speed temp starts rising past half way point which is when i shut it off. no leaks, has coolant.
not sure what the problem. water pump/headgasket? hope not head gasket
if anyone could share some light on this it would be great tomorrow im taking it in to dealership to get checked out and fixed
4.0 v8
Old May 9, 2012 | 09:25 PM
plums's Avatar
First suspect is always bleeding the cooling system.
Then, is your waterpump flowing? Quick check: is the hose from the cool side(outlet) of the radiator getting hot? Or at least warm. If not, that indicates a lack of flow.
Your fan control does not know the coolant temperature in the radiator, only that the coolant at the sensor is too hot.
Old May 10, 2012 | 02:13 AM
JagV8's Avatar
Water pump is a suspect as I believe the blades can break off. But check all the others too.
Old May 10, 2012 | 07:42 PM
QuartzSTypeR's Avatar
Are you getting heat in the cabin?
Old May 12, 2012 | 12:29 PM
dealer fixed it yesterday, it was just a " tower peice" behind thermostat leaking
mrplow58
Jan 21, 2024 05:53 AM
Booskisjag
May 5, 2016 09:38 AM
abonano
25
Sep 25, 2015 10:43 AM
Raul Lara
Sep 14, 2015 07:31 PM
Raul Lara
Sep 2, 2015 05:23 PM
