Fender liners...
Old Apr 29, 2025 | 02:30 PM
scrannel's Avatar
Default Fender liners...
Still cleaning up after rat blitzkrieg, (although foxes have moved in next door and rats have booked), and was wondering how much of a nightmare it is to put in new fender liners (front). Looks not hard, but... thanks.
Old Apr 30, 2025 | 08:15 AM
Peter_of_Australia's Avatar
Swapping wheel arch liners is very easy, but note that some of the fixing elements, which look like philips-head screws are in fact those fixing elements, where you need to pry out that, which looks like the philips-head screw from its surrounds with a tiny screwdriver or similar and then pull out the complete fixing element. And some if not all of those will break, but you can buy them on cheap online platforms.
And why do you want to swap them? Is there no way to weld the broken plastic back together again?
Old Apr 30, 2025 | 09:24 AM
scrannel's Avatar
Thanks! Yes, suppose I could patch, but once off they don't seem that expensive so...
Old Apr 30, 2025 | 06:56 PM
It took me a while to find it - the thread, where I described, how I fixed my wheel arch liners with bits of wire and a soldering iron, but here it is, in case you want to to that route:
https://www.jaguarforums.com/forum/s...cement-288446/
It is really not that difficult to remove them.
But while you have them off, it might be a good idea to replace the fuel filter, which is hidden behind the left wheel arch liner...
Old May 1, 2025 | 08:24 AM
scrannel's Avatar
Thanks for the advice and the link. Hope to play with my baby in a week or so!
Old May 2, 2025 | 12:34 PM
scottjh9's Avatar
You will find amazing clear views of what is behind those liners. Take advantage of it
Old May 3, 2025 | 10:38 AM
clubairth1's Avatar
Community Influencer
They were too expensive from Jaguar for me. I got and installed the cheap after market versions. I mean for $50 you get a pair of them.
So pretty cheap. Now they are NOT as good as the Jaguar ones as they are thinner and more flexible plastic. But that's not all bad and they seemed to hold up anyway.
S-Type Fender Liners
Old May 3, 2025 | 11:59 AM
scrannel's Avatar
Thanks Scott and Club -- sounds like an adventure! Have to fix what some rats did -- good news is now that Foxes have moved into the neighborhood, rats are history.
Old May 4, 2025 | 07:05 PM
Just remembered something: If you plan to swap the fuel filter, while the wheel arch liner is off, it would be an annoying experience to have all the parts at hand, but not being able to get the old fuel filter off. These are very handy tools for that - very cheap and they seem to have them e.g. on Amazon:
Old May 5, 2025 | 04:12 PM
scrannel's Avatar
Thanks again Peter! Will check them out!
Beretta9
Nov 13, 2024 07:21 AM
No Quarter
Jan 16, 2022 01:14 PM
TomcatJag
Jul 2, 2021 09:33 PM
iramphal
Apr 19, 2020 06:59 PM
Erik van Harten
XF (X260)
Aug 17, 2019 11:31 AM
