A Few Questions About Transmission Issues....
Old Feb 19, 2012 | 10:11 PM
LoganWolf's Avatar
Default A Few Questions About Transmission Issues....
I recently purchased a 2003 S type V8 and have the surging rpm issue and the "lurch". Both problems developed over the course of the past three days as the weather has gotten colder. It seems to improve as the engine gets warmer.
As I have read I need to change the fluid and have both the PCM and TCM reflashed. A fluid change will not fix this alone. Sound Ok so far?
I have 65,000 miles on her.
Is changing the pan necessary?
I have had several opinions from friends and two techs. as to which fluid to use. Is there another brand that will work in my car besides Jags. liquid gold? What do you guys suggest? I would prefer to pick it up locally. In the past I have used Mobil 1 synthetic and Valvoline Max Life on my other cars with good results.
Also, how much can I expect (aprroxamitely) to pay from the dealer to have the PCM and the TCM reflashed?
Finally, is there a DIY for changing the transmission fluid with pics?
Thanks for any advice.
Old Feb 19, 2012 | 10:34 PM
LoganWolf's Avatar
I think I found one of my answers on CTS's site and I also found this PDF of approved oils.
I would still like to hear from you guys on this.
File Type: pdf
Old Feb 19, 2012 | 10:46 PM
H20boy's Avatar
lots of threads on the subject of transmission fluid, you'll find just as many opiniont as well. I chose to use Lifeguard6, along with the pan in a kit from theCTSC, price is about $275 IIRC, some reason they aren't showing the price anymore on the website.
I've seen someone use Mobil 1, another used Ford Mercon SP, do your research and find the one that you are most comfortable with.
Old Feb 19, 2012 | 10:47 PM
H20boy's Avatar
oh yah, the VW group use the same fluid, and I've heard you can get it alot cheaper from them too.
Old Feb 20, 2012 | 08:19 AM
jimlombardi's Avatar
Default 6HP30 Transmission - DIY and weblinks to related info
Hi
There is really a lot of information here on the forum about changing the 6HP30 transmission fluid on your S-Type.
Below are weblinks to DIY Video, Forum Posts, JTIS instructions, Lurch info/theory, Fluid Change Packages, and Road Fly member DIY experience.
HOW TO: Change the transmission pan/fluid for 6HP26 (Video) FAQ go to post# 1 dated 3/5/2011
https://www.jaguarforums.com/forum/x...q-50868/page2/
Lurch info/theory post:
https://www.jaguarforums.com/forum/s...y-24552/page4/
More info on 6HP30
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-15/zf-6hp26-information-42164/
https://www.jaguarforums.com/forum/x...it-sale-44764/
The CTSC - The California Transmission Supply Company ---- Oil Pan with integrated filter for 6HP26
http://www.thectsc.com/index.php?p=product&id=1&parent=9
roadfly.com thread on 2004 S type 6HP26 transmisson fluid change – post# 16 dated 6/20/2009
Change Transmission fluid in Jag
JTIS Extracted PDF file on 2003 S-Type Transmission Fluid R&I
2003 S-Type 6HP26 fluid change.pdf
Hope this helps
Jim Lombardi
Old Feb 20, 2012 | 08:25 AM
The pan change is necessary as the filter is integral with the pan.
You should also consider changing the electrical sleeve at the same time.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
ahunt4
Sep 14, 2015 08:17 PM
AtholC
Sep 9, 2015 09:07 PM
