Finding error codes with OBD2: O2 Sensor
Old Oct 27, 2011 | 07:46 AM
chromedragon's Avatar
Default Finding error codes with OBD2: O2 Sensor
I finally purchased an ELM327 and downloaded the appropriate software to my Android. I was pleasantly surprised at how nice the app works. I was not so happy finding two error codes.
I know I must change one of my O2 sensors, and I know it is one of the two before the catalytic converter. My problem is, where are they located?
While looking around in the engine compartment, I can see two sensors toward the bottom of the firewall. They seem to be attached to something under the car. Could these be the sensors?
What I plan on doing is first checking for a loose connection then reversing them. This way I will know which one is defective.
My JTIS CD is currently damaged and I am not even sure it will run on my PC (I recently upgraded WIN7) even in compatibility mode.
Any help will greatly be appreciated.
Old Oct 27, 2011 | 07:58 AM
JagV8's Avatar
Don't know on the V6 but often they're "more" (as in: semi-) accessible from underneath. You'd need the engine undertray off (as when changing oil).
Rick will know
Don't be surprised if you break one/both when trying to remove them as they can be "tight".
magmedia
Aug 15, 2019 08:54 PM
carl purchase
Oct 14, 2015 06:14 PM
Poet
Oct 2, 2015 09:00 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
