The Finger-Slicing Driver's Door Lock Problem....
Old Dec 22, 2011 | 01:59 PM
Jon89's Avatar
Default The Finger-Slicing Driver's Door Lock Problem....
I remember several members here posting quite a while ago that the foil edges of their drivers-side interior door lock button began to separate, exposing sharp edges that in some cases sliced up their fingers when they attempted to lock or unlock their door. This happened to my wife yesterday, so I need to resolve it. So to those of you who have experienced this problem, how did you fix it? Peel away the metal foil and just leave the white plastic exposed? Replace the component with a new one (if so, how much and where did you source it)? Or just ignore it and always remember to use the lock/unlock button on the dash whenever you are inside the cabin?
Yes, I did a search before posting using "sharp edges drivers door lock handle". Nothing came up, which surprised me since I remember this being discussed several times. But I don't remember how the affected members fixed the issue....
Old Dec 22, 2011 | 02:55 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
I just use the door handle to open the door upon exiting. You might want to put a small bit of scotch tape (or equal) for now around that item until it can be fixed. That should save her fingers for now.
Old Dec 22, 2011 | 02:58 PM
JagV8's Avatar
I don't think it was posted under many/any of the obvious keywords
Might include
unlock
and/or
peel
and/or peeling
which won't be unique enough I guess
I think it's not a handle (arguably) and that the poster may not have mentioned sharp or edge.
Old Dec 22, 2011 | 03:25 PM
xjrguy's Avatar
For a short while Jaguar made the little chrome cap available to fix that, but it was only available for about a year. Now the only way they have to fix it is the entire interior handle assembly. I haven't heard of any other method, maybe someone else has.
Cheers,
Old Dec 22, 2011 | 08:59 PM
Toller's Avatar
It's hard for me to picture exactly where this is happening but...could clear nail polish work to solve the problem?
Old Dec 22, 2011 | 10:50 PM
xjrguy's Avatar
No, when that chrome peels it is deadly sharp. Attached is a little something that explains it pretty well.
Cheers,
File Type: pdf
Old Dec 23, 2011 | 08:11 AM
Jon89's Avatar
Thanks for the feedback. Sure wish that chrome cap that xjrguy mentioned was still available. Perhaps it did not stay on, and that is why it was discontinued....
I am not willing to purchase an entire new interior door handle assembly because I believe the problem will simply reoccur. I may cover the edge with duct tape for the time being, or I may decide to peel off all of the metal foil, leaving the white plastic underneath. And if I do that, I may attempt to paint the white plastic with a silver-finish paint....
The easiest solution is to never touch that button, using the door lock/unlock button on the dash instead. I have explained that to my wife. But she still wants the sharp edges removed....
Our other three door locks do not suffer from this problem. Yet....
If I come up with an effective solution, I'll let you know....
Old Dec 23, 2011 | 09:41 AM
joycesjag's Avatar
jon
I have/had a couple ideas:
1) On a whim, I called motorcarsltd, sadly Ken Karr has moved on, but I did speak to a rep. and inquired if they carried the replacement chrome lock cover....simply stated no, the rep. hung up on me prior to asking if they carried a replacement door handle assembly, new or used.
2) Could the edge be filed down, from the looks of Steves pdf file (post #6 thank you Steve), it appears that the chrome lockcover is easily removed.
3) With the chrome lock cover removed, I wonder if it could be sent off to a plastic chromer and be rechromed. I am sure that this could be done very inexpensively
Again just my meandering thoughts.
JOsworth's Avatar
To try and be constructive, Jon. Take it apart. Peel off the metal plate exposing the plastic. Get some plastic adhesion promoter (like a primer for plastic). Then get the silver metallic spray that they sell in the auto parts place. It won't look perfect but will probably hold up better.
BTW, when I traded mine it had just started peeling as well.
Just saw Rick's solution (number 3) and like that one much better than mine...But I'll leave mine there for poops and snickers...
Old Dec 23, 2011 | 09:44 AM
Jon89's Avatar
Just spoke with forum sponsor Nalley Jaguar. From a parts standpoint, they can only sell me the entire door handle/lock assembly. They had never heard of the chrome cap solution that xjrguy mentioned earlier. Our member price is $106 for a new door handle/lock assembly. I'm not willing to do that since I believe the peeling foil flaw was never addressed and a new piece will eventually suffer the same fate. So for the time being, I have placed a small piece of duct tape over the offending sharp edge. Certainly not a permanent solution, but it will prevent future finger cuts on the wife until I can come up with the permanent fix....
Old Dec 23, 2011 | 10:13 AM
JagV8's Avatar
Maybe they'd have more luck with the jag part #s (in the PDF xjrguy posted). XR856669 looks to be available over here (hmm, if it really is) www.jagspares.co.uk/Manners/partdetail.asp?partno=XR856669
Old Dec 23, 2011 | 10:54 AM
xjrguy's Avatar
Well, that's certainly interesting, John........ Nice job!
I wonder if someone would actually get one if they ordered it??
I knew I always hung on to this weird stuff for SOME reason!
Cheers,
Old Dec 23, 2011 | 11:31 AM
joycesjag's Avatar
Hey NOW!!!!!!
Damn I must be bored today,
Jon and John, I just contacted Scott Jaguar Charlotte, Wayne (parts guy) says part # XR856669 (chrome lock cap) is available as a special order..... hold on to your britches........$7.83.
Old Dec 23, 2011 | 12:19 PM
xjrguy's Avatar
Originally Posted by joycesjag
Hey NOW!!!!!!
Hmmmm. I'm not sure your guy did his due diligence. The part # does show up in the catalogue, but it supersedes as "No Longer Available". In Parts Communication it shows as no stock at any plant within Jaguar.
I hope I'm wrong, I like cheap fixes!
Cheers,
Old Dec 23, 2011 | 12:31 PM
Jon89's Avatar
Thanks Rick. It's worth a try, so I'll call the Greensboro and Cary dealerships with the part number to see what they say. I'm not expecting it to be available, but we'll see....
Old Dec 23, 2011 | 12:44 PM
JagV8's Avatar
umm, it's not even that cheap
just cheaper than the whole caboodle
Old Dec 23, 2011 | 12:54 PM
Jon89's Avatar
The Greensboro dealer's parts department says that their system shows a total of four of these chrome caps in stock at other dealers around the country. They said they will acquire one of these and sell it to me for $7.30 plus tax. With the holidays upon us, they expect it will take them a week or so to get the item in hand. So we'll see if it actually shows up there, or if they call me back to say it was all a mirage and the caps are no longer available....
Thanks again, Rick....
Old Dec 24, 2011 | 10:10 AM
Jon89's Avatar
Update:
A closer read of xjrguy's PDF attachment above seems to indicate that XR856669 is the chrome cap cover for the RIGHT-side interior door locks of the S-Type. XR856670 is apparently the chrome cap cover for the LEFT-side interior door locks of the S-Type, which is the side I need. With the Greensoboro dealership now closed for Christmas, I won't be able to clear this up until early next week....
Old Dec 24, 2011 | 11:06 AM
xjrguy's Avatar
Update:
I'll be interested as well. I neglected to think about the idea some dealer somewhere might still have an old, no longer available part laying on a shelf in a corner.
I'm curious too about the website JagV8 found. Time will tell......
Cheers,
Old Dec 24, 2011 | 11:21 AM
Staatsof's Avatar
Yeah it happened to me and I just avoid the damn thing.
"My kitty bit me today" or something like that ...
I always wondered if careful masking, a work blanket on the interior and a whole lot of patience would allow one to use crazy glue to get that chrome to adhere to the button again?
I never tried it.
It's a total POS.
Jaguar's not handling this properly is one reason these cars have such a dismal resale. Infiniti handled stuff like this really well when I had issues. All cars have issues. It's how it's handled that counts.
Let us know if the replacement stuff works and thanks for pursuing this.
