Free Suspension Parts
Old Feb 14, 2017 | 10:57 PM
davidladewig's Avatar
Default Free Suspension Parts
I have some parts to give to anyone who can use them. Brand New.
These are Rear Tie Rods. I ordered them and when I went to install them, they were about 3/4 of an inch too long. My mistake. They do NOT fit a 2000 model. I did bolt them on to see if they would make it, but they don't and someone else may be able to use them. I can't send them back so no worries and I have replaced them with correct new ones.
The correct model fit is 2001-2008 S types.
They came from AM Parts. The AM part number is AM4086464028. The manufacturer part number is 1ASTE22547.
If anyone could use a new set of these tie rods, let me know and I'll send them to you.
Old Feb 15, 2017 | 03:36 AM
Datsports's Avatar
pm sent , cheers
Old Feb 15, 2017 | 07:35 AM
jagstuart's Avatar
pm sent also -stu
Old Feb 15, 2017 | 07:38 AM
aholbro1's Avatar
Arrgh! Wish you'd have screwed-up 3 months ago!
Old Feb 15, 2017 | 06:02 PM
abonano's Avatar
Are you sure they won't fit the 2000 model? Did you screw the tie rod all the way in? They're a pain to install. When I did mine I had to enlarge the hole where the tie rod goes into the bracket.
I'll never do that job again.
Old Feb 15, 2017 | 06:59 PM
I'm very sure. You can't even use the tightening nut with these, so I looked up what I bought and it was clearly marked 2001-2008..NO 2000. Now that I've installed the correct ones, it is obvious as to the difference. The 2000 rods are made backwards of the later rods. It took longer to jack the car, put the stands under it and get out the tools than to install them. If you use your floor jack to raise or lower just the suspension, they go right on. One bolt and a nut for each side.
The key is measuring as has been shown before. Measure the old rod from end of the stud to the center of the mounting sleeve where the bolt goes. Be sure the stud and sleeve are NOT crooked. The measurement should be exact. Close won't do. Do one side at a time and your alignment will not change. I checked each rod 3 times before I put them on. Wala....alignment good and no rotted rubber. Success. PS: I bought a lifetime alignment thing from firestone so I get it checked whenever I want to. Good plan.
Old Feb 16, 2017 | 05:08 PM
abonano's Avatar
How funny. I have a lifetime alignment plan from firestone too. I bring it every 6mos... They hate it! One mgr told me they should've never sold it to me as it's an exotic car and they need a European specialist.
After I stopped laughing I told him it's a Ford in Jaguar clothing, gave him the specs and had it realigned within 25 mins...
Mine were a bear to get in. Both nuts were rusted and I had to cut both studs out with a hack saw... Glad I'm never doing that again!
Old Feb 16, 2017 | 07:44 PM
They don't make money doing it over and over, do they?
I sprayed PB Blaster on all the old parts and they came right off, but I live in the south and all that rust I see on photos here, I don't have.
I sent the mismatched parts to New Zealand today. Datsports was first in line. I hope they work on his car. If they don't, I know how to make them work.
Old Feb 17, 2017 | 07:14 AM
solidaxel's Avatar
Well I am 2 days late!
I bought the same rods, and yes there were 3/4" too long to get them in the same location as the old ones.
Here is what I did to solve the problem
take the rods apart like you show and cut 3/4 to 1" from each piece
Screw them back together and get your measurment within 1/16" and you still have enough thread to toe/in or tow out
I took total length with the car sitting on the ground
I guess I will find out next week when I have it alinged
Old Feb 17, 2017 | 07:59 AM
I could have done what you are talking about, but I would have taken it one step further. I would use a die and lenthen the threads 3/4 of an inch and then cut off the 3/4 inch. That way there is plenty of adjustment thread to get the measurement exactly right. The manufacturer says 2001-2008. If the manufacturer is wrong then the 3/4 rule goes into effect. Had I figured this out before I re-ordered the rods, this thread would not exist.
Old Feb 18, 2017 | 05:08 PM
solidaxel's Avatar
So by threading the inner rod you are just giving yourself more toe in adjustment?
I still have two threads of adjustment and the new rods are in the same location as the old ones I took off
If you do not cut the threaded rod it will bottom out before you reach final adjustment
Old Feb 18, 2017 | 05:40 PM
Right, you add threads and then cut off the end so it won't bottom out, but remember that is on my 2000 which is not what was spec on this set. These were 2001-2008 and that must be different than mine or some factory made a godzillion of these wrong. Wouldn't that be a mess! Should work out fine.
My old ones weren't worn out , just the rubber that keeps them lubed.
Old Feb 19, 2017 | 10:21 AM
solidaxel's Avatar
Has anyone tried to replace the bushing and sleeve with a urethane one at the wheel end?
Old Feb 19, 2017 | 02:33 PM
Donna's Avatar
I did mine last year... Can you screw up on some front end suspension parts please ;-)
Old Feb 19, 2017 | 08:34 PM
NO. Not in the plans this week. What front end parts do you need?
Old Feb 20, 2017 | 02:23 PM
Donna's Avatar
Most of them from weeping CATS to stabilizer bar rubbers... Ive done the easy stuff, lower tie rods etc. but she still loves to clunk her way over the slightest dip in the road!
Old Feb 20, 2017 | 05:40 PM
Yes, they will clunk. The video posted here helped me a lot to find the clunks. I've gotten most of them out now. The rubber grease seals are worthless after a few years, but O'Reilly's Auto Parts here has some generic ones. I haven't tried them, but might go look at them to see if they would work.
Old Feb 25, 2017 | 09:41 AM
Jason Souhrada's Avatar
Do you still have these? I need them zip code south carolina 29576
Old Feb 25, 2017 | 10:54 AM
aholbro1's Avatar
You could just read the thread....
https://www.jaguarforums.com/forum/s...9/#post1622542
Old Feb 26, 2017 | 08:03 AM
solidaxel's Avatar
Well the Jag is complete and the rear Specs. were .02 different than the align sheet quoted, so he set it to factory (Revised) specs.
He said there was still some lee way on the rods for more adjustment, so I am convinced the rods will work by removing 3/4 to 1 inch from inner and outer threaded part of the rods, with out threading the inner rod
