Front Hub.....Where to buy?
Old Sep 19, 2011 | 08:58 AM
EZrider800's Avatar
Default Front Hub.....Where to buy?
Strange thing happened the other day. 3 wheel studs broke for no apparent reason. The tire has been on the car for thousands of miles so I don't think the wheel was installed improperly. No noise or vibration before it happened like it was loose or anything. They just broke and THEN there was a vibration!!
The car is a 2003 S-Type and I'm told I have to buy the front hub as the wheel studs are not available separately. My local dealer in Chattanooga wants $359.27 and Nalley in Atlanta wants $329.00 so it's not cheaper enough to offset the freight.
Anybody know another place to buy a front hub at a discount? Thanks in advance!
"EZ"
Old Sep 19, 2011 | 09:04 AM
EZrider800's Avatar
I found this Timkin part on Parts Geek.com. It's about $200 cheaper. Does it look correct? Anybody ever tried one of these?
03 2003 Jaguar S Type Wheel Hub Assembly - Driveshaft & Axle - OES Genuine, Timken, Front - PartsGeek
Thanks.
Old Sep 19, 2011 | 09:05 AM
I don't think Nalley will charge shipping on an order of that value.
You can change the studs, I beleive the Lincoln LS ones will fit.
https://www.jaguarforums.com/forum/s...l-studs-60686/
Old Sep 19, 2011 | 09:42 AM
EZrider800's Avatar
Both Jaguar dealerships confirmed that the studs were not available. They said the only way is to replace the whole hub. (Nice huh?)
I have tried Lincoln LS parts before and they didn't fit. (window regulator) I may just buy the Timkin brand front hub for $111.00 and be done with it.
Old Sep 19, 2011 | 10:39 AM
Your choice, did you take a look at the link? I seem to recall there being some problem with the hub offset on replacement hubs? Maybe it was Joycesjag who mentioned it.
775da23c.jpg?t=1312164841
Old Sep 19, 2011 | 10:48 AM
Seems like it was SKF hubs that were the problem, you might want to be careful.
https://www.jaguarforums.com/forum/s...g-right-56531/
Old Sep 19, 2011 | 03:07 PM
bfsgross's Avatar
Call Coventry West (Atlanta, GA.) or Jaguar Heaven (CA.) for a low mileage used hub? Less $$
Old Sep 19, 2011 | 03:38 PM
EZrider800's Avatar
Hopefully the Timken part will be correct. I did not buy the SKF part. If it's wrong they have the OEM part for $277 ($80 cheaper than my local dealer) I'll let you know how it goes.
Old Sep 20, 2011 | 06:41 AM
The Chris X's Avatar
Hopefully the Timken fits. I use that brand on my Jeep since it is very hard on the unit bearing hubs due to the bigger tires - the Timkens tend to last much longer than the OEM or other aftermarket units.
Old Sep 20, 2011 | 09:56 AM
eds123's Avatar
You can change just the studs.
Old Sep 20, 2011 | 12:04 PM
bfsgross's Avatar
That's what I thought.
Old Sep 20, 2011 | 02:05 PM
That's what I said, I thought the picture illustrated it quite well.
It's a horses and water thing.
Old Sep 21, 2011 | 08:40 AM
EZrider800's Avatar
Eds123, bfsgross, Norri,
Where would I buy FRONT wheel studs separately if the dealers do not stock them? From my experience when I had rear studs break, the studs are a Jaguar only item that regular auto parts stores do not carry.
Have any of the three of you ever actually replaced the front wheel studs on your S-Type? Where did you buy your studs? Part number?
Thanks.
Old Sep 21, 2011 | 09:09 AM
Personally, No but i beleive that Eds changed all his. Perhaps he can confirm?
Part numbers are in his thread.
Old Sep 21, 2011 | 02:12 PM
EZrider800's Avatar
OK. I ordered part# 610-484 from Rock Auto so if the new hub from Timkin doesn't fit I'll have a back up plan. Sounds like I may need a few spare wheel studs anyway after reading that thread. Good Lord I have never had a car that routinely broke wheel studs before. I'm not even using the junk stock lug nuts!! I have 18" chromw wheels and after market lug nuts so it isn't the 2 piece lug nuts causing the issue. But I've had 8 studs break so far................
Old Sep 21, 2011 | 02:25 PM
That is pretty wild dude. Are these stock chrome wheels or aftermarket? If they are aftermarket, do they use/need hub centric spacers? If so do you have them? How high are your torque values on the studs - overstretching could be an issue.
Just some random thoughts - seems to be something more at play here....
Old Sep 21, 2011 | 02:31 PM
eds123's Avatar
I've replaced all my wheel studs. After the first one done the rest are easy. You ordered the correct part number as it is the same for F/R. The front is easier than the rears. Remove wheel, remove caliper, remove rotor, hammer studs loose, remove 4 bolts on back of hub and 1 plug, once removed finish removing studs and insert new ones, repeat process backwards. I bought some washers and cheap lug nuts to pull the stud through the hole.
Yes, the studs do suck. You can try to defend them saying they were torques wrong, etc. But, mine were rust welded to the lugs and broke off. My Porsche and former toyotas required torque spec that were never followed and I never had any problems. These are a definite weak link.
Old Sep 21, 2011 | 02:56 PM
^ good info - didn't realize they were that bad. Crazy they rust welded in Orlando! Dang...
Old Sep 21, 2011 | 03:58 PM
Good info Eds, thank god for that dry AZ heat, nothing gets rusted badly.
Old Sep 21, 2011 | 07:41 PM
eds123's Avatar
It was a Jersey car for the first part of it's life so I'm assuming it was from there. Never had any problems with a car from Florida so I hope the new studs stay this way!
