Fuel gauge
Old Mar 25, 2014 | 06:48 AM
bossnagy's Avatar
Default Fuel gauge
The fuel gauge on my '03 STR never goes above 3/4. Is there a calibration procedure or is something else wrong? Any ideas.
The range on this thing is bad enough without having to fill up more frequently.
Old Mar 25, 2014 | 09:03 AM
Jon89's Avatar
A couple of other STR owners here have reported similar fuel gauge inaccuracies. I believe the fix turned out to be new gauges. Perhaps those guys will chime in here and provide you with complete details....
Old Mar 25, 2014 | 09:37 AM
police666's Avatar
Check the UK forum, the are a few posts on the problem including how to replace the stepper motors and where to buy then
Old Mar 25, 2014 | 09:38 AM
Mikey's Avatar
Does your gauge sit on 3/4 for the first 100 miles or so and then start to drop? How does the 'miles till empty' reading correlate?
Old Mar 25, 2014 | 09:47 AM
bossnagy's Avatar
I wish it stayed still for 100 miles, at least accurately. It drops rather rapidly, somewhat related to the movement of the pedal on the right. The miles to empty display was fairly accurate, ie within a few miles on a 60 mile highway trip. I've had it showing 0 miles to empty a few times.
Old Mar 25, 2014 | 10:03 AM
Mikey's Avatar
It may not be the gauge then. I've got an issue with my non-R that's similar. In the research I've done it might be the left tank sender. Won't know till I can get the car back on the road next month, if the snow ever melts.
Old Mar 25, 2014 | 10:13 AM
bossnagy's Avatar
I'm thinking that it's just not getting filled up. I've tried to "stuff it", but the most I can get in, when it's showing 0 to empty, is 13.2 gallons. I've bravely put at least 5 miles on it when is shows 0.
Old Mar 25, 2014 | 10:47 AM
Mikey's Avatar
You may want to crawl underneath and look at the bottom of both gas tanks. They're not far from the jacking pads where the car is supported while on a two post lift.
Old Mar 25, 2014 | 01:32 PM
JagV8's Avatar
Bear in mind the reserve, which is still there when 0 first shows. But even more bear in mind that the pumps are fuel-cooled and not cheap to replace if cooked!
Look up ETM (see below) and in there you can see the 2 senders. Fill to full, use ETM, they should read similar (and I think it's near 255). Rock car and watch them to get an idea whether they're seeing sloshing. If one's a bit low I suppose if it doesn't move much then probably a bad sensor but if it moves around quite a bit then it's just not full.
TBH I just fill as needed. It's an R so fuel vanishes...
Old Mar 25, 2014 | 02:41 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Could be the jet pump. I had a similar problem and the dealer replaced it and all was good.
ccfulton
Sep 20, 2015 05:15 PM
10 XF Premium
Sep 19, 2015 08:48 PM
Ragn0r
Sep 19, 2015 08:39 AM
adamn
Sep 10, 2015 09:23 AM
AL NZ
Sep 4, 2015 08:39 PM
