fuel injectors
Old Mar 25, 2011 | 08:08 AM
achysklic's Avatar
Default fuel injectors
Ok I think I want to pull out my injectors to clean them or maybe even replace them. I have looked but not found much.
What is involved in removing them?
Does the intake need removed?
2005 4.2
Old Mar 25, 2011 | 08:34 AM
Gus's Avatar
Gus
Why remove and clean them when all you need to do is add BG 44K to your fuel and drive.
Old Mar 25, 2011 | 08:54 AM
achysklic's Avatar
I add Lucas fuel injector cleaner ever other tank..
My problem is the previous owner was horrible at doing anything for this car. I am sure it put the cheapest lowest octane crap he could in it..
After I bought the car I changed the original fuel filter and it looked like mud comming out of the out fuel filter.
This drives me crazy and I really want to make sure they are cleaned right for proper fuel mileage.
They last tank of gas I have got my car when first started idles rough then 10 seconds later smooths out and runs perfect.
Just to be on the safe side I want to check them out.
Old Mar 25, 2011 | 09:03 AM
Brutal's Avatar
its easy to take them out and you can send to InjectorRx - Professional ultrasonic fuel injector cleaning, flow testing and balancing service.
they give a before and after performance printout, ultrasonic clean and replace screens and orings. All for $18ea theres nothing better to clean and injector and theyll perform like new again. tank and onboard cleaners will not clean anything out of the injector basket screens, besides Ive pulled many a Jag injector and todays additives and ethanol eats away the baskets
Old Mar 25, 2011 | 09:31 AM
achysklic's Avatar
Sounds awesome, does the manifold have to come off to remove injectors?
Old Mar 25, 2011 | 09:36 AM
Brutal's Avatar
No just the fuel rails, use compressed air to blow all the dirt off and away from the injectors before removing, and when you reinstall lube the orings and slides straight in so you dont cut a orings. Thats not easy to do (cut an oring) cause the openings are chamfered, but still be carefull
Old Dec 11, 2011 | 06:00 PM
Patrissa's Avatar
how do i remove fuel injectors on a 2000 s-type 3.0
Old Dec 12, 2011 | 06:53 AM
police666's Avatar
pdf files from JTIS with removal/instalation instructions for :
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Fuel pressure regulator.pdf
Hope tis helps
Old Dec 16, 2016 | 10:22 AM
dpasek's Avatar
Default Missing files
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Hope tis helps
These links return file not found messages from Mediafire servers.
Can someone please post new links?
Old Dec 16, 2016 | 11:37 AM
Mikey's Avatar
Octane level of a fuel has nothing to do with the volume, type or quality of cleaning additives.
This has nothing to do with the injectors.
Old Dec 16, 2016 | 11:54 AM
JagV8's Avatar
Just download the free workshop manual.
moff1959
Sep 26, 2015 05:35 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
reb1999
Sep 25, 2015 10:00 AM
