Global open and close
Old May 20, 2008 | 04:32 PM
gbdiver's Avatar
Default Global open and close
Now I have found that the global open works, wonderful idea, I am unable to get the global close operating via the remote.
I used to be able to use the key but some bright spark has decided to insert a foreign object into the hole.
Is this a programming issue (global close via remote) or am I SOL?
Mark
Old May 20, 2008 | 07:30 PM
FactoryJaguarTech's Avatar
Default RE: Global open and close
If 2003 or newer it can be programmed.
Old May 20, 2008 | 07:44 PM
gbdiver's Avatar
Thanks mate. It is a 2001 model so am I SOL?
Old May 21, 2008 | 12:35 PM
Mines at the dealer for a couple of other things, I asked if they could programme the Global Closing, they said no problem but they charge 1hr at $135. Maybe other dealers will be more accomodating!
Old May 21, 2008 | 01:28 PM
cosworth's Avatar
That's crap. I got my drive away lock disabled for $20 during an oil change.
Secondary but on topic. For sure a 2000 S cannot have global close programmed?
Old May 21, 2008 | 07:33 PM
Some of them can....it depends on the vehicles software. We charge half hour for the job. So about $60.00.
Old May 21, 2008 | 07:45 PM
gbdiver's Avatar
Is there a list of what can and cannot be programmed on a 2001? How do I find out what software version I have?
Mark
Old May 21, 2008 | 09:36 PM
bobby181's Avatar
hey how is every one? i have a 03 s-type i have tried to have the Global close programed to my car with the remote, and i took it to two dealers and they both said it cant be done. i told them that other peolpe have it done. they say it cant. be done.were is it is the pid's section on the WDS/IDS. how can i found out how to have it programed. i all sowould like to know what can and cannot be programmed?
Old May 22, 2008 | 01:48 PM
ORIGINAL: FactoryJaguarTech
That would seem more reasonable, but as it is a dealer only thing you either have to pony up or travel to another dealer.
Florida is too far for me
Old May 23, 2008 | 02:01 AM
badmojo's Avatar
According to the owners manual you cannot global close with the remote only open. It says that you can only global close with the key!
Old May 23, 2008 | 02:18 AM
Well I can confirm that mine is now opening and closing with the remote, so it is possible.
Old May 23, 2008 | 12:55 PM
Cajun Mojo's Avatar
Default Global open and close - open & close
OK IF IT CAN BE DONE: OPEN & CLOSE WITH THE REMOTE
. . . . . . . . . . HOW DO YOU DO IT ????????????? [sm=smiley21.gif]
Old May 23, 2008 | 06:42 PM
gbdiver's Avatar
ORIGINAL: norri
Norri,
How was it completed and what year and model is your Jag?
Mark
Old May 24, 2008 | 11:45 AM
'03 S Type.
Just simple programmng I believe, the car was in for an AC condenser and reverse sensor module, and they did the open/close mod at the same time.
I remember reading posts a while back saying that some dealers will not do this for some reason and IIRC wether or not is possible depends if your car has the safety clutches fitted to the window mechanisim.
Maybe one of the Techs can confirm this?
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Aus V8S
Nov 13, 2015 11:01 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
findre
Sep 10, 2015 05:46 PM
