Global open (windows) problem.
Old Nov 1, 2014 | 12:02 PM
Bad Cattitude's Avatar
Default Global open (windows) problem.
When I first got my STR, I programmed the fob to activate the global window open option, and it worked as described: Hold unlock button and all windows and sunroof open simultaneously.
Lately I noticed that I have to actually open a door for this to work. ie: it does not work from a distance anymore. The door unlock and trunk open functions still work at a good distance so I assume it is not the battery.
Suggestions?
Old Nov 1, 2014 | 12:35 PM
JagV8's Avatar
Bad contact? Fob battery dying?
Old Nov 1, 2014 | 03:17 PM
The door unlock and trunk open functions still work at a good distance.
Old Nov 1, 2014 | 11:15 PM
aholbro1's Avatar
But those functions are single-press. Global is press and hold. Could be your (FOB) battery is borderline and doesn't support a strong signal for the required elapsed "Hold" time?
Old Nov 2, 2014 | 11:17 AM
Possibly... Only one way to rule out the battery - change it!
Old Nov 4, 2014 | 06:56 PM
Nope, not the battery... suggestions?
Old Nov 5, 2014 | 12:41 PM
aholbro1's Avatar
Does this mean your global open only works with the key in the the door now? Not from the FOB? Or does it mean global open works fine from the FOB but only after you physically open a door?
I'd try disconnecting the battery and grounding the two leads together for 15-30 sec, then hook everything back up....sometimes the modules get confused and just need a reset.
Old Nov 5, 2014 | 12:51 PM
tbird6's Avatar
Well I don't know but I have had problems with a FOB before and the only answer was to replace the whole thing.
I tried battery replacement, cleaning contacts and button replacement but in the end none of it worked and I can't explain why.
Old Nov 6, 2014 | 12:57 PM
aholbro1's Avatar
I rarely use global open...but have had several occasions where a FOB would quit working for normal lock/unlock....thus far always resolved by using the other FOB a few times or for a week or so and then the errant one returns to the fold and decides to work again for no apparent reason.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
