Global open (windows) problem.
When I first got my STR, I programmed the fob to activate the global window open option, and it worked as described: Hold unlock button and all windows and sunroof open simultaneously.
Lately I noticed that I have to actually open a door for this to work. ie: it does not work from a distance anymore. The door unlock and trunk open functions still work at a good distance so I assume it is not the battery.
Suggestions?
Suggestions?
But those functions are single-press. Global is press and hold. Could be your (FOB) battery is borderline and doesn't support a strong signal for the required elapsed "Hold" time?
I'd try disconnecting the battery and grounding the two leads together for 15-30 sec, then hook everything back up....sometimes the modules get confused and just need a reset.
Well I don't know but I have had problems with a FOB before and the only answer was to replace the whole thing.
I tried battery replacement, cleaning contacts and button replacement but in the end none of it worked and I can't explain why.
I rarely use global open...but have had several occasions where a FOB would quit working for normal lock/unlock....thus far always resolved by using the other FOB a few times or for a week or so and then the errant one returns to the fold and decides to work again for no apparent reason.
99xk8guy
Sep 29, 2025 10:51 PM
kabs3012
Sep 12, 2015 10:40 AM
