On going rear BCM issue on a 2003 Jaguar s-type 4.2 liter
Old Sep 7, 2013 | 08:25 PM
Candy's Kitty's Avatar
Default On going rear BCM issue on a 2003 Jaguar s-type 4.2 liter
originally my car was not getting any fuel I couldn't figure it out as I went through everything replacing the fuel pump fuel pressure regulator sensor fuel filter, fuse, and relay. I finally decided to take it to a Jaguar mechanic. They said the rear BCM needed to be replaced. So I replaced it. The car was finally running but it was immediately in limp mode. I figured this was a result of the bank2 up stream O2 sensor being bad. Seeing as I didn't have any money to fix the sensor I had to drive the car for a while. Just yesterday it did the same thing as when the bcm went bad. The fuel gauge read empty when I knew I had over a Quarter tank and the display did not say "fuel low". I'm sure the bcm went bad but what could cause it to go bad again?
stanjag
Dec 29, 2024 08:26 PM
neruda
Sep 3, 2015 07:45 PM
dpappyp
Aug 27, 2015 06:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
