Help for Fuel Indicator
Old Oct 2, 2013 | 05:26 AM
JIB's Avatar
JIB
Default Help for Fuel Indicator
Hello everybody! I was surfing the web to seek help and discovered this Forum. Congratulations to all of you and here I am with my request.
I own a 2004 S-type Gasoline 2,5 V6 Exe model. I live in Italy and car has 72000 Kms total life. After having halted the car for one year (for too many reason I avoid to describe as boring), last week I could restart her, so I took her to a Mechanic and he had to exchange, besides the oil and filters, the battery, the gasoline contained into the tank, the fuel pump and fuel filter, and the two fuel senders as they rusted due to the presence of water into the tank.
But even tough the car is perfectly running and tuned up, the fuel indicator is still jammed on the zero position, and with a 50%tank filled up, it does Not show any indication, nor the LOW level Fuel Warning light comes on and consequently no indication of data from the Computer in terms of Endurance or Instantaneous consumption. We tried to reset by removing battery cable, by checking fuse or wires, but no success.
Before bringing again the car to a far away distance official Jaguar dealer and discover something stupid...is anyone of you guys keen to give me any idea on what to check or to reset?
Thank you!
Old Oct 2, 2013 | 06:37 AM
police666's Avatar
Check connections on fuel sender unit at tank
Old Oct 2, 2013 | 06:42 AM
JagV8's Avatar
You can see raw readings using ETM (see my sig)
Old Oct 2, 2013 | 07:38 AM
JIB's Avatar
JIB
Thank you Police666, I will test and check those connections! Good idea. I will make a list of all hints to my Mechanic and then post results! ;-)
Old Oct 2, 2013 | 07:39 AM
JIB's Avatar
JIB
Thank you JagV8, I don't think my Mechanics has an interface to comply...I will enquire about. ;-)
Old Oct 2, 2013 | 10:07 AM
Mikey's Avatar
Have a read here:
https://www.jaguarforums.com/forum/s...-error-103335/
I'm still not sure what causes the error or why filling the tank 'cures' it but it's food for thought.
Old Oct 2, 2013 | 10:25 AM
JagV8's Avatar
Er, what interface? None needed.
Old Oct 2, 2013 | 11:29 AM
JIB's Avatar
JIB
Originally Posted by Mikey
Have a read here:
I read your link Mickey, thanks...I will fill it up to try this easy one. I will keep you posted.! Thanks.
Old Oct 2, 2013 | 11:32 AM
JIB's Avatar
JIB
Sorry JagV8, in this case I do not understand what did you mean in your first post as "raw reading" using ETM...
Old Oct 2, 2013 | 12:13 PM
JagV8's Avatar
See my sig for ETM then Search, it's all free
dsnyder586
Dec 29, 2024 07:39 PM
hamilton7550
Jul 30, 2021 11:29 PM
JWheeler
Nov 22, 2019 08:28 AM
dstary
Sep 19, 2015 09:47 AM
Mosers63
Sep 6, 2015 02:53 PM
