Help?How do I change the fog light bulb on an S-type ?
Old Dec 26, 2009 | 06:48 PM
kparsells's Avatar
Question Help?How do I change the fog light bulb on an S-type ?
How do you change a bulb on a stype fog light? The manual says send in for service and Im not going to do that to change a bulb so whats the seceret?
Old Dec 27, 2009 | 09:09 AM
joycesjag's Avatar
Default 2005 fog lamp replacement w/pics
The fog lamp cover has plastic tabs that need to be "popped" out. No tools required. I started at the grill portion and worked toward the fog lamp itself. Reach in and twist lamp harness.
Attached Thumbnails Help?How do I change the fog light bulb on an S-type ?-2005-fog-lamp-003.jpg   Help?How do I change the fog light bulb on an S-type ?-2005-fog-lamp-001.jpg
Old Jan 1, 2010 | 09:45 PM
Shibajack's Avatar
How about on an older model 2000 s-type? How do you get to the fog lights?
Old Jan 2, 2010 | 07:27 PM
kparsells's Avatar
Cool 2000 model
similar to an x5 bmw
take the air sperator off first if you have one 3 Small clips turn them 90 degrees and take off now remove the 2 Black plastic covers next to the fog lights there along side of them
3) unscrew 2 screws from ech light housing and pull it out
from behind twist to the left and you will see the H3 bulb undue the clip or squeeze and you are good to go
not as hard as it sounds
take care
Old Jan 2, 2010 | 07:31 PM
kparsells's Avatar
I left the answer at my thread good luck
Old Oct 11, 2014 | 07:25 PM
cppeabody's Avatar
I have the same question, only for the 2000 3.0 S-type.
Old Oct 12, 2014 | 04:50 AM
Paul792's Avatar
This question has been answered for your model by kparsells.
When I did this job. The outer plastic part (wiring side of connector) was seized together and fell apart in my hand. So it may be brittle.
take care
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
bdboyle
Sep 4, 2015 06:16 AM
pocketrocket
Sep 3, 2015 07:44 PM
OkieTim
Sep 2, 2015 12:48 PM
