HELP my A/C blows hot air
Old Jun 20, 2008 | 05:47 PM
Mike E's Avatar
Default HELP my A/C blows hot air
Hi everyone OK this is my problem I got a 2003 S-Type R my front left and right and the rear back vents is blowing hot air when I turn on the A/C and the front middle vent is a lil cold but not as cold as it should be. So I took it to a shop after it got the A/C recharge it was doing the same thing so I took it to another shop that work's on Jags they put it on the machine and told me it was the heater valve and auxiliary water pump so I got those change and it still does the same thing. PLEASE HELP me if you had the same problem know what it is Thanks
Old Jun 20, 2008 | 06:16 PM
jag_genius's Avatar
Default RE: HELP my A/C blows hot air
have had similar problems after installing valve.. found out that the pins were stretched out.. after i pushed them in..worked perfectly.. also had heater core.. also have seen post evap sensors fail..
Old Jun 20, 2008 | 06:19 PM
Mike E's Avatar
Where is the pin at?
Old Jun 20, 2008 | 06:37 PM
jag_genius's Avatar
pins... are right front lower side.. under the electric pump passenger side.. of the engine pay.. front of engine between rad fans ,..
also had corroded harnesskeeping valve not closed..
Old Jun 20, 2008 | 06:45 PM
Mike E's Avatar
I'm gonna give it a shot, ill try to find it do you got any pic where is at?
Old Jun 20, 2008 | 07:32 PM
jag_genius's Avatar
no .. connector is there if you look staright down.. 3 pins..
Old Jun 20, 2008 | 11:35 PM
Mike E's Avatar
Is it the red, blue, orange wire?
[IMG]local://upfiles/4320/06C6F5FD0CE24F46AB5B831E4A4B879A.jpg[/IMG]
Old Jun 27, 2008 | 03:55 PM
Mike E's Avatar
From this day I still don't know what it is, but when I find out Ill post it up but if you find out let me know. and all i got to say about the heat is park your car n drive your other car that's what im doing.
Old Jul 3, 2008 | 02:40 PM
Mike E's Avatar
Old Jul 3, 2008 | 02:44 PM
KAZsam's Avatar
Mike find yourself a nice girl that blows cold air problem solved! have a good 4th of July
Old Jul 3, 2008 | 02:45 PM
Mike E's Avatar
hahhaha good one happy 4th July
Old Jul 13, 2008 | 03:33 PM
Mike E's Avatar
check out this link i tired messing with my car but it didnt do any thing mybe ill fix your problem
http://www.jaguarforum.co.uk/viewtopic.php?t=2600 let me know if you find out what it is
Old Feb 4, 2009 | 01:58 PM
Mike E's Avatar
Still blowing Mix Air anyone have the same problem and got it fix?
Old May 1, 2009 | 09:44 PM
Mike E's Avatar
Unhappy
Help!!!
Old May 2, 2009 | 12:08 AM
Jagernaut's Avatar
I've had the same problem with my Jag. Replaced the same valve as you. I've been told it is the climate control head unit that is causing the problem. Haven't had it replaced yet..it is next on my list.
Old May 3, 2009 | 11:56 PM
Mike E's Avatar
keep me posted if you find out the problem because it sucks to drive a Jag on summer time with your window roll down when is over 100 degree.
Old May 4, 2009 | 12:57 AM
12RM's Avatar
My guess has already been suggested, corroded wiring loom which can cause a number of problems. This being one of them, fairly common on the later facelift cars.
Old May 25, 2010 | 04:23 PM
jaguarclimatecontrol's Avatar
Follow this procedure to help narrow down the possible source(s) of this problem.
Use a multimeter and take some measurements:
1. Run the engine.
2. Set the controls to max "Lo" for both driver and passenger sides.
3. Confirm that the air is still blowing hot (take note which vents blow).
4. Disconnect the plug from the coolant control valve and take voltage measurements at all 3 contacts in the plug. The middle contact should read 14v or so.
5. Take resistance measurements at the 2 outer contacts in the plug (measure between each contact and a chassis ground). The 2 outer contacts should read close to 0 ohms.
6. Jumper the middle contact in the plug to the middle contact at the valve. Jumper one outer contact in the plug to the corresponding outer contact at the valve using the multimeter to measure current. Be careful that you don't short anything with the middle contact in the plug (it's always hot +12v-14v). Repeat the measurement at the other outer contact after disconnecting the first outer contact (don't disconnect the middle contacts yet). Each measurement should read 0.6 to 1.1amps.
7. With the middle contacts still jumpered between the plug and valve, jumper an outer contact on the valve to a chassis ground, while using the multimeter to measure current. Check to see if any vents blow cooler air during this grounding process. Repeat the measurement at the other outer contact and check the vents again.
8. Reconnect the plug to the valve.
9. Shut off the engine.
10. Report the results.
