HELP ! my gear is stuck at P
Old Oct 1, 2011 | 03:39 PM
JagBoy3's Avatar
Unhappy HELP ! my gear is stuck at P
Hello every one im new here i would like to discus my problem in order to look for a solution and help others who could face a same one.
I have s-type jag 2003 v6, the engine starts normally but a yellow light with a restricted performance message is displayed, when i press the brake pedal to shift the gear it doesn't shift and the clicking sound is not heard i tried million times and nothing is going well
I checked all the fuses and all work good!
So what the problem could be ??
Old Oct 1, 2011 | 03:54 PM
phd12volt's Avatar
did you pop up the shifter assembly yet?
Old Oct 1, 2011 | 04:09 PM
eds123's Avatar
Check the 2 bolts that the shifter wire attaches to located underneath the car. One of mine came loose and wouldn't allow me to shift either. The bolts are known to work loose. I don't have the link handy but search transmission bolts.
Old Oct 1, 2011 | 04:58 PM
JagBoy3's Avatar
No i didn't
Im also thinking that this might be the problem, but can you tell me exactly where i can find those bolts and if u have a picture of it or the place where it is located.
thanks in advance
Old Oct 1, 2011 | 06:55 PM
vance580's Avatar
I'll do one better watch this and skip to about 1:10 of this video and it will show you the bolts.
oilchange2 - YouTube
Old Oct 1, 2011 | 07:10 PM
JagBoy3's Avatar
well "vance580" now i can fix my car at home while watching your channel
thank you
Old Oct 1, 2011 | 07:14 PM
JagBoy3's Avatar
let me try it tomorrow cuz my car is parked at the college :P
Old Oct 1, 2011 | 10:44 PM
ohsigmachi's Avatar
My gear shift got stuck also. The solenoid inside the shift mechanism died, and there is no separate solenoid sold, jag only sells the entire J-gate assembly. 700+ bucks to replace mine.
Old Oct 2, 2011 | 08:31 AM
clubairth1's Avatar
Community Influencer
Also something to remember. DON'T GET ROUGH WITH THE SHIFTER!!!! You will break it and has been posted it's very expensive. It's tempting to keep pulling on the shift lever but it's plastic and you will over power it.
You have been given the two most likely things. The bolts under the car on the tranny and the solenoids inside the car in the console.
Now here is an easy one and always check it first. Do you have brake lights? If not then you can't shift out of park because the car thinks you don't have your foot on the brake pedal while shifting out of park.
Old Oct 3, 2011 | 06:46 PM
cue244's Avatar
Mine is hard to shift out of park when I am parked in my driveway with a slight incline. I have to pull a little hard to get it into reverse.
Old Oct 4, 2011 | 01:54 AM
JagV8's Avatar
Sounds like it's not fully held on the parking brake. Whether that or not, if it's harder to get out of P then you risk the commonish failure
Old Oct 4, 2011 | 09:34 AM
eds123's Avatar
I agree with Jagv8.....maybe the e-brake pads are done and need changing.
Old Oct 4, 2011 | 10:34 AM
Brutal's Avatar
Originally Posted by ohsigmachi
my gear shift got stuck also. The solenoid inside the shift mechanism died, and there is no separate solenoid sold, jag only sells the entire j-gate assembly. 700+ bucks to replace mine.
take a striaght razor blade to the plastic pin the locks the shifter cam and voila, no more shifter lock
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Ragn0r
Sep 29, 2015 10:38 AM
