Help need with ignition lock.
Old Aug 6, 2012 | 01:55 PM
Simon.h's Avatar
Default Help need with ignition lock.
Hi all,
I have been trying for the last 2 hrs to remove the ignition switch, it says in JTIS- detach the ignition switch lock cylinder and remove, but i can't see how.
Its a late 2002 onwards UK car.
Thanks.
Old Aug 6, 2012 | 02:34 PM
joycesjag's Avatar
Sorry Simon, I just looked it up on alldatadiy and they are as vague as JTIS.
Good luck, and if you are able please take some photos and post them up when you figure it out.
Old Aug 6, 2012 | 02:42 PM
joycesjag's Avatar
I correct myself from above.
1) Turn key to position I
2) Release the retaining tang
3) Remove the ignition lock cylinder
Hope this helps.
Attached Thumbnails Help need with ignition lock.-ignition-lock-assembly.jpg
Old Aug 6, 2012 | 03:01 PM
Simon.h's Avatar
Cheers, but my problem is i can't remove the switch from the dash.
Old Nov 16, 2013 | 10:29 AM
PatrickO's Avatar
Did this ever get fixed/resolved...?
Old Nov 16, 2013 | 10:40 AM
Welcome to the forum Patrick,
Perhaps you should post an intro in the new members section then explain your problems in the tech section.
Old May 9, 2014 | 12:43 PM
rwcjag's Avatar
I have been trying for the last week to remove the ignition Barrel and switch,on my 2.5 2003 s-type but i can't see how. Can anyone help me please.
Old May 9, 2014 | 05:29 PM
Welcome to the forum rwcjag,
We got your identical 'reported post' in the Moderator Forum.
You don't have sufficient posts to be able to open PDF's on the forum so I've put the JTIS (Jaguar Technical Information System - the Workshop Manual) Ignition Switch Lock Cylinder Removal procedure PDF on my MediaFire account for you. You can download it from this link:
http://www.mediafire.com/view/0u79xa...k_Cylinder.pdf
Post again with further details on how far you have got with the removal if you need more information.
Also, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old May 10, 2014 | 03:13 AM
Corv's Avatar
Banned
Can you post some photos of the switch/barrel?
The switch/barrel is probably secured by shear bolts. Look for what appears to be rivet heads.
Old May 10, 2014 | 03:26 AM
Simon.h's Avatar
No!
It turned out to be a fault with my remote!
Old May 11, 2014 | 01:58 PM
rwcjag's Avatar
Sorry I which I could but it's in the car still I am trying to take it out.
Thanks.
Old May 12, 2014 | 04:29 AM
Corv's Avatar
Banned
Thanks.
I asked for photos so I could tell you how to to remove it.
If it is attached with shear bolts, they need to have the heads drilled out or ground off. You might even be able to get a hold of the heads with vice grips if there is enough room, in order to unscrew them, who knows.
Old May 12, 2014 | 12:01 PM
rwcjag's Avatar
Thank you for the pictures It help me a bit but it doesn't tell me how to remove it for the car.
Old May 12, 2014 | 12:24 PM
JagV8's Avatar
Take it to someone who's used to working on cars.
MILOU13
Nov 25, 2015 02:39 AM
3lvis
Oct 1, 2015 01:56 PM
millertic
Sep 30, 2015 08:11 PM
euphoniaob
Sep 30, 2015 10:50 AM
