Help replacing fender
Old Dec 11, 2013 | 05:34 PM
usajay38's Avatar
Default Help replacing fender, see my video
Over the weekend I had a small fender bender. My front pass side fender needs to replaced. My question is, do I need to remove front bumper cover to replace the fender?
Also my a/c stop working about a month ago, now it's making noise. Can I bypass the a/c with a shorter belt, if so what length of belt do I need?
John
Old Dec 11, 2013 | 05:55 PM
tony1963's Avatar
Yes, you'll have to remove the bumper cover and undo the inner fender liner. I believe that the rocker panels also needs removed.
As far as bypassing the AC compressor, why not just fix it?
Old Dec 12, 2013 | 02:13 PM
tbird6's Avatar
You live in Florida and want to bypass your A/C???
Old Dec 12, 2013 | 03:46 PM
police666's Avatar
I live in the UK and couldn't do without ac
Old Dec 12, 2013 | 05:01 PM
usajay38's Avatar
I don't have money right now to replace a/c system. I will replace it before summer.
I will try this weekend to replace fender.
Old Dec 15, 2013 | 07:30 AM
usajay38's Avatar
It turned out not to be my a/c but my belt tensioner pulley. I will tackle this job over the weekend also. Any tips for an easy install.
Thanks.
Old Dec 15, 2013 | 09:51 AM
usajay38's Avatar
Checkout video with sound, it this the pulley?
Old Dec 15, 2013 | 10:05 AM
usajay38's Avatar
IMG_1433_zps0803c100.mp4 Video by jleon04 | Photobucket
Old Dec 15, 2013 | 10:30 AM
leaping cat's Avatar
it sounds more like coming from the engine. timing chain tensioner maybe.
Old Dec 29, 2013 | 03:01 PM
usajay38's Avatar
Ok, my car has been parked since last post. I was able to see that timing chain and tensioners were replaced in 2006, my questions is should it have worn out in 7 years and need to be replaced again? The work was completed at Jag dealership with 77,xxx miles now it has 166,xxx miles.
thanks
Old Dec 29, 2013 | 03:26 PM
clubairth1's Avatar
Community Influencer
Did they use the all metal version? By 2006 they should have.
The all metal ones seem to last fine but you can check pretty easy by taking off a cam cover. You can see the secondary tensioner then but not the primary one.
Old Jan 12, 2014 | 12:56 PM
usajay38's Avatar
Ok I remove belt and no more noise, it's the a/c clutch. Should I replace clutch or just a new compressor. How hard or easy to replace compressor?
Old Jan 12, 2014 | 03:06 PM
NBCat's Avatar
Ok I remove belt and no more noise, it's the a/c clutch. Should I replace clutch or just a new compressor. How hard or easy to replace compressor? Thanks
It is better to replace the compressor and clutch together since the compressor must be removed to replace the clutch.
There are four bolts holding the compressor, which can be accessed from the lower LH front. Remember to replace the two compressor manifold o-rings prior to reassembly and add sufficient compressor oil to the new unit. The Bentley workshop manual has all the details.
Prior to removing the compressor, the system will need to be discharged by a local workshop with the equipment to capture the freon/refrigerant as it is now illegal in most places to simply let the refrigerant escape into the atmosphere.
Old Jan 21, 2014 | 12:13 AM
usajay38's Avatar
Ok help guys, I unhooked air intake tube removed belt, started vehicle and it's the ac compressor. Replaced ac compressor, replaced air tube, now vehicle will not start. What could it be, I checked all connection nothing look unhooked.
Old Jan 21, 2014 | 03:04 AM
JagV8's Avatar
Check for OBD codes, then using OBD go round the sensors checking them for anything weird.
But first check your battery is really well charged and good. Recharge after.
Old Jan 21, 2014 | 11:23 AM
usajay38's Avatar
Battery was placed on batt charger, fully charged. Don't have an obd. I only started veh like 5 sec without belt on. Is there any connection near the belt I could have knocked loose when I removed it?
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
