Help! Stuck in Park! no park lites blinking
Old Jan 18, 2017 | 04:44 PM
03styper120k's Avatar
Default Help! Stuck in Park! no park lites blinking
Ok here is whats going on
I charged battery and trunk came open in rain storm
Iv got CATS error yellow lite
Iv got no blinking parking lite
Iv got no S mode lite working on shifter
only electrical thing not working is gas cap opener
I took cats box apart no water in it clean no burnt caps or anything , dried out back of car no corrosion on connector's
Iv checked switches on Brake pedal (working passing +)
took apart shifter I have + volts to solenoid and no Negative ground when pressing brake etc
I cant find any fuses blown in whole car.
Checked shock wire connectors nothing
I can move manually solenoid and it will shift no problem
Whats nxt ? thanks in advance
Old Jan 19, 2017 | 08:28 AM
pab's Avatar
pab
Take the belly pan off and look for two small bolts on the side of the shifter. They get loose and fall out then the car no go...
Plenty of post on this site about the problem. Very common.
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
Old Jan 19, 2017 | 09:36 AM
Jon89's Avatar
He said the trunk opened in a rainstorm, so he probably has water in the trunk well. Water ingress can affect a number of the electronic modules located in that area....
Old Jan 19, 2017 | 10:54 AM
Ducmon's Avatar
How much water was in the boot because you will have to get it dried out completely. The easiest way is too get rid as much of the water as possible would be to put a bag of rice in the boot and let it the water out.
Old Jan 19, 2017 | 11:10 AM
Yes its all dried out its been sitting for a month . nothing wrong with bolts on bottom . it will shift fine if I move solenoid back with screwdriver .
Does anyone know what relay controls Brake pedal park lock it has to be in back also The gas cap dosnt work unless you do it manual with cable pull.
Old Jan 19, 2017 | 11:56 AM
melhookv12's Avatar
Are your brake lights working ?
Old Jan 19, 2017 | 12:10 PM
Yes brake lites working and yes both switches on brake pedal are working passing power turning off and on when pressed
Old Jan 19, 2017 | 12:22 PM
Ducmon's Avatar
did you remove the battery. If so have you reset the car. see this thread
Resets Required after Flat Battery or Changing Battery in a Jaguar
Old Jan 19, 2017 | 12:46 PM
yes Did reset already.
Old Jan 19, 2017 | 01:03 PM
JagV8's Avatar
You will need it completely dried out and may then have some permanently damaged items which you'll need to replace, sadly.
Pray it's not the fusebox!
Old Jan 19, 2017 | 01:15 PM
Ducmon's Avatar
Have you read the codes. They might push you in the right direction and show what to check in the JTIS.
Old Jan 19, 2017 | 01:30 PM
JagV8's Avatar
the modules in the rear need a jag-type tool
Old Jan 19, 2017 | 05:35 PM
There are no codes .....today I found the gas cap relay and fixed that so gas cap works ,
I read somewhere there is supposed to be clicking in back when pressing brake pedal can someone tell me what relay this is please I have no clicking on relay in trunk when pressing brake ...
also today gave the solenoid a negative wire and it does work like its supposed to . i have lost my shop disc and dont know were the ground come from or what relay in rear is for brakes ????
Old Jan 20, 2017 | 01:25 AM
Ducmon's Avatar
If you go here you can download a copy of the JTIS because without knowing the date of manufacture of your car. It is difficult to answer your questions.
https://www.jaguarforums.com/forum/general-tech-help-7/jtis21-win7-64-install-method-new-archives-65926/
just follow Jim's instructions and then you will be able to find out for yourself.
Old Jan 20, 2017 | 03:24 AM
JagV8's Avatar
Originally Posted by 03styper120k
There are no codes
If you didn't use a jag-type tool you have no idea what codes you have
edit: inserted specific quote
Old Jan 20, 2017 | 06:12 AM
Ducmon's Avatar
That is why I showed him that thread so that he can get the program and the tool.
Old Jan 20, 2017 | 06:46 AM
JagV8's Avatar
It looks more about JTIS than IDS / WDS or the like, but I've clarified.
Old Jan 20, 2017 | 07:17 AM
Ducmon's Avatar
Mutual misunderstanding,
If you go to this thread you can get a copy of SDD program v1.30. This version is clean of viruses, it has been found that the version that comes with the mongoose from China has one.
mongoose v130.
Old Jan 20, 2017 | 08:11 AM
JagV8's Avatar
Note: you also need to buy a Mongoose or suitable (J2534) device!
Old Feb 16, 2017 | 06:08 PM
So I replaced the suspension module in trunk with a used one and the suspension lite has gone out... Now I need the interlock relay were is it? so your saying my scan tool is not pulling jaguar codes ? the files listed will not install in my laptop period. I replaced the rear backup sensor module and no go no change all tho original module had signs of water in it.
Im ready to shoot this car !
