HELP - Transmission issues
Old Jan 30, 2016 | 05:30 AM
car5car's Avatar
Any transmission problem diagnosis should start with ATF level.
Old Jan 30, 2016 | 07:33 PM
BlackKat's Avatar
Thanks. I have replaced pan and added new fluid. I've check the fluid according to spec a few times. Still having the save symptoms.
Old Jan 30, 2016 | 11:31 PM
abonano's Avatar
Have you checked the sleeve for leaks? Any leaks in that sleeve will wreak havoc with the TCM and cause all sorts of issues...
Old Jan 31, 2016 | 02:57 PM
BlackKat's Avatar
I have replaced the connector sleeve. No leaks from there prior or after replacenent.
My car finally gave me some codes. P0306 (misfite cylinder 6) and P1643 (ecm to tcm communication fault).
I replaced all plugs yesterday and the #6 coil, solved all problems. No more jerking at idle, no more slip, no more squawk. I guess the tranny was getting confused with what the engine was doing.
Hope this helps the next person before ordering a tranny rebuild.
FYI it's an 04XJR. Thanks!
Old Feb 1, 2016 | 01:33 PM
car5car's Avatar
Originally Posted by michaelz
Ok they are not condemning the transmission yet, but they replaced the battery cleared the codes and it's still doing it. They are getting a TCM to the ECM code P1643 (CAN) I believe and they can't determine what is causing it. The fluid is fine and they are perplexed at why a trans with 45k miles would do this.
I just fixed that problem, let us see how smart mechanics in your shop are.
Old Feb 1, 2016 | 01:49 PM
JagV8's Avatar
2-year old post - he's NOT going to be doing that!!
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Sep 25, 2015 11:09 AM
carelm
Sep 5, 2015 01:13 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
