Hose Clamp Pliers?
Old Mar 14, 2016 | 11:28 AM
kr98664's Avatar
Default Hose Clamp Pliers?
Greetings All,
Does anybody have a recommendation for tools for the flat band clamps on the cooling system hoses on our cars? I was locked in mortal battle with them yesterday, using long needlenose and other assorted pliers.
Lisle offers these, but the ends look rather bulky for access in tight spots:
http://www.amazon.com/dp/B0002NYB6Y/ref=wl_it_dp_o_pC_S_img?_encoding=UTF8&colid=2L0QNSIJMC8K2&coliid=I24ATRPOTSV9LQ http://www.amazon.com/dp/B0002NYB6Y/ref=wl_it_dp_o_pC_S_img?_encoding=UTF8&colid=2L0QNSIJMC8K2&coliid=I24ATRPOTSV9LQ
OTC (and others) offer a cable style, but these only work at a right angle to the hose:
Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive
Thanks for any suggestions.
Old Mar 14, 2016 | 11:43 AM
I have the OTC type that I got from Sears.
Old Mar 14, 2016 | 12:23 PM
NBCat's Avatar
The constant tension hose clamps are better for the plastic couplings as they cannot be over tightened, but they can be difficult to remove or even move.
The first set are good, while the second image is for clamps in really tight places. Both should work fine if designed for the flat version of the clamps.
Old Mar 14, 2016 | 10:42 PM
abonano's Avatar
I've used the cable type with limited success..
Old Mar 15, 2016 | 08:26 AM
Ragn0r's Avatar
Old Mar 15, 2016 | 12:33 PM
kr98664's Avatar
I did a little more poking around. I've ordered these two, as they had the most compact heads among all the different brands, plus I've had good results with other Gearwrench products.
Amazon.com: GearWrench 3976 Straight Hose Clamp Pliers: Automotive Amazon.com: GearWrench 3976 Straight Hose Clamp Pliers: Automotive
Amazon.com: GearWrench 3977 Angled Hose Clamp Pliers: Automotive Amazon.com: GearWrench 3977 Angled Hose Clamp Pliers: Automotive
After they arrive, I'll let you know how they work. Fingers crossed.
PC210
Mar 16, 2016 02:07 PM
bullittandy
Mar 13, 2016 09:43 PM
TexMurphy
Mar 13, 2016 09:07 PM
Vector
US Lower Atlantic
Mar 13, 2016 04:07 PM
