How clean is your engine?
Old Sep 20, 2022 | 03:01 PM
Rober2's Avatar
Default How clean is your engine?
I want a clean and presentable engine on my 01 S-type. Any suggestions on what I should use for cleaning? Any 'do not's? Did anyone chrome any part/s of it? Can you post photos? Thanks
Old Sep 21, 2022 | 01:42 AM
JagV8's Avatar
Do not use water, do not disturb anything mechanically or electrically.
You risk a nightmare.
I'd spend the same time making sure it's maintained (e.g. replace hoses, worry about vacuum lines, use OBD extensively, study the forum posts for ideas).
Old Sep 21, 2022 | 09:45 AM
motorcarman's Avatar
Jaguar issued info for you.
File Type: pdf
Old Sep 21, 2022 | 01:47 PM
Like a feline's posterior. I believe our American friends use a somewhat more earthy expression for this level of cleanliness.
As posted above, avoid water anywhere near electrics or you will certainly regret it. Wrap anything you need to keep dry in aluminium foil or clingfilm before applying any product. I use an 'orange degreaser' (biodegradeable and solvent free cleaner) in a spray bottle and then clean off the dirt with paper towel. Here's an example although there are many types available:
I'm not a fanatic when it comes to engine compartment cleaning but I like it to appear as if someone has actually looked in there since it left the factory.
Old Sep 21, 2022 | 03:21 PM
Sportston's Avatar
Give the car an ORS. If anyone asks what ORS means you tell them it is ‘original specification service’. Actually it means ‘oily rag service’ but you never tell a customer that. Get one clean rag nice and oily and wipe everything under the bonnet with it to make things look shiny and clean without risking water ingress.
Old Sep 24, 2022 | 04:16 PM
Rober2's Avatar
Thank you all for the advice. I started with an oily rag to be safe. Then, I saw that the plastic cover that needs cleaning, and it just came off with very little resistance. Underneath the cover looks like it is supposed to attach to something, but there is nothing there to attach to. Is this how it should be? It is a 2001 S-Type.
plastic cover
Are these supposed to attach somewhere?
Also, I think I would like to paint the cover red. Comments? Do I need a high temp paint?
Old Sep 24, 2022 | 05:38 PM
NBCat's Avatar
They are supposed to press onto the centre bolts for the cam covers that have extensions. It appears someone has put the bolts in the wrong positions on the cam cover.
If you are painting the cam cover(s), use engine or high heat paint.
JimC64
Detailing / Car care
23
Mar 29, 2018 05:01 PM
andyXJR
May 30, 2017 11:40 AM
Thegaff1
Apr 1, 2017 08:56 PM
0x61
Jun 14, 2013 06:45 AM
