I bought this bmw transmission kit...
Old Oct 14, 2015 | 10:20 PM
n2audio's Avatar
Default I bought this bmw transmission kit...
New BMW 6HP26 Auto Transmission Oil Filter Pan Repair Kit 24117571227 | eBay
There's a thread on here somewhere talking about this kit and that it fits our transmission perfectly.
Ordered 8qts of mercon SP too.
I'll try to remember to follow up on how bad I butcher the job (it's always something).
Old Oct 14, 2015 | 11:53 PM
ssshield's Avatar
Good luck brother. Definitely should sticky this thread if it does fit your TypeR tranny correctly.
Old Oct 15, 2015 | 02:11 PM
n2audio's Avatar
It's not TypeR. I wish it was. Just a basic 3.0L.
Previous poster Staatsof used this kit.
https://www.jaguarforums.com/forum/s...n-leak-137943/
I got the kit, 8 qt Merc SP, a new IR thermometer and a new manual fluid pump all for
about $143
Old Oct 15, 2015 | 03:40 PM
tbird6's Avatar
Lets hope it has the right O-rings on the sleeve.
Old Oct 21, 2015 | 09:24 AM
n2audio's Avatar
I've read/watched several different how-to's for the transmission work. It seems straightforward enough however I'm absolutely certain I will find some obstacles as I always do. I'll have seized pan bolts and/or seized fill plug. Who knows, but it will be something that should take 2 min and I'll turn it into 2 hrs. That's how I roll
I think my biggest challenge from the start will be lifting it. A couple yrs ago I took the trans out of a taurus and it took me ~2 hrs to get it high enough with my assortment of cheap floor jacks, cinder blocks and pieces of 2x12 (it's a top notch operation). I don't have to go quite as high for this, but the combination of high enough and level will take some time.
I'm a little concerned with dealing with the exhaust as well, but I'm sure I'll find a way around that.
Old Oct 21, 2015 | 11:25 AM
Jon89's Avatar
Four industrial-strength jack stands are mandatory for this job if you plan to do it on your back. Rick (joycesjag), Wayne (cjd777), and I will be doing a ZF 6HP26 drain-and-fill on my 2005 S-Type at Rick's house near Charlotte next Tuesday morning using Mercon SP. We know from previous experience that big, rock-solid jack stands are always Step Number One....
Old Oct 21, 2015 | 02:02 PM
n2audio's Avatar
A couple cheap jacks, two cheap jack stands, two ramps, and some blocks -- Check!
30" of space I had to come up with to get the AX4S out of my Taurus, I think I can handle half that for the pan and fluid on this one.
Old Oct 22, 2015 | 08:43 AM
TonyX's Avatar
Two additional things I would consider must for this project:
1. 8mm allen wrench cut to 0.75inch length. This will fit on the fill bolt and allow you to use regular wrench to turn it.
2. Garden pressure sprayer. 1.5 gallon, clean and with tip bent in J shape. This allows you to pump up the new fluid with the least of fuss. Bend the J shape with little bit of heat and allow it to take set.
Old Oct 22, 2015 | 08:51 AM
n2audio's Avatar
The sprayer's a good idea - and I already have one, but clean up would be a real treat.
I'll keep that in mind if the hand pump I bought is a bigger hassle than expected.
I bought a new cheap set of allen wrenches that can be cut up if needed. Need new cut-off disks for my rotary tool
Old Oct 23, 2015 | 09:06 AM
n2audio's Avatar
Question:
What's the little black mystery thing nobody ever talks about?
The pan,
the bolts,
the sleeve,
(shameless KC Royals plug BTW )
Old Oct 23, 2015 | 09:22 AM
JagV8's Avatar
Flux capacitor
Old Oct 23, 2015 | 09:29 AM
Jon89's Avatar
That mystery part might be exclusive to BMWs. I didn't get one of those with the kit I ordered from Klaus at the CTSC Company back in July 2013 to do the ZF 6HP26 pan replacement, sleeve replacement, and ATF refresh on my wife's 2006 XK8....
Old Oct 23, 2015 | 09:43 AM
n2audio's Avatar
Originally Posted by JagV8
Flux capacitor
GREAT SCOTT!!
Why didn't I think of that?!
Old Oct 23, 2015 | 02:59 PM
n2audio's Avatar
Been doing a little looking around.
The pan supplier is Bapmic which is apparently a german company.
Never heard of the brand, don't know anything about them.
Old Oct 23, 2015 | 03:20 PM
Jon89's Avatar
ZF is also a German company....
Old Apr 29, 2019 | 04:57 PM
Riccixj's Avatar
I know this thread is old but love the car. I was looking at these wheels as well and while searching for them this thread popped up on google.
Been looking to get some new wheels from stock 19 to either 20 or 21 inch. I was thinking about 21 inch but the sidewalls or small that Im worried about the ride quality and bent wheel factor
any ways NICE CAR
Old Apr 30, 2019 | 01:33 PM
Joedotcom's Avatar
Hi
The Mystery part goes under the mechatronics and it the seal for the flow and return to the torque converter, these are know to split
also if your thinking of changing this, there should be some other sleeves that you are missing
cheers
Joe.
teacoff
Nov 27, 2022 05:36 PM
Danny Collins
Feb 28, 2017 02:44 AM
Ronco1
Oct 20, 2015 12:32 PM
scarbro2011
Oct 19, 2015 11:59 AM
dkress
Oct 11, 2015 03:11 AM
