I made my trans issues worse
Agree. E Clutch first thing to go on these transmissions unfortunately
What’s bothering me is that it didn’t have a 3-4 shift issue before I put the new valve body in it. I wonder if one of the new solenoids is actually bad. It didn’t have any shifting issues or codes before I “fixed” it… perhaps I’ll put my old solenoids in the new valve body. Just sucks that I have to spend another $125 on fluid.
No sports mode.
Drive gently for the first 50 miles (critical) ensuring shifts (1-2, 2-3, 3-4 and 4-5) all happen around 1,600 rpm (SC cars - around 1,400 rpm; FYI not easy but doable).
Same with downshifting, especially 2-1 downshift, no gas, light braking.
Also, when parked, when trans is warm. Shift from P to R, then N then D then 2, 3, 4, 5 and back to D, then N then R then Park with 7 -10 seconds between each shift point.
Do that 3 times...
After 50 miles you can get a bit more aggressive but still take it easy. Do so for about another 200 miles.
Drive normal, not aggressively. No hard upshifts/downshifts and no "sports" mode throughout the above.
The later IDS reprogramming seems to not need CODED ACCESS and the drive strategy of the early configuration is changed but you can still drive the car as per the TSB S303-17 to obtain the desired result?
I left the dealer in 2006 so I ONLY did the drive cycle in the TSB S303-17.
Catching up on this post, awesome. For anyone's that does not have IDS/SDD here is what you do.
No sports mode.
Do that 3 times...
No sports mode.
Do that 3 times...
Thank you for your help!
I would have much rather had the TCM reflashed, but I couldn't find anyone to do it. The local dealerships told me they wouldn't touch it due to age. In hindsight, I could have bought the stuff to reflash it myself for the cost of the valve body, solenoids, and service parts.
blocked solenoids and piston wear is pretty common. throwing in a VB in combo in with a reset will keep clutch adapts down
The software is complicated but I have always found that IF you try a RESET ADAPTATIONS and the software is 'out of date', the IDS will state that the TCM will need a REFLASH. IF the software is the latest that the diag computer is loaded with, the ADAPTATION ONLY will proceed.
Sometimes the ECM and TCM reprogram alert will come up on the screen and the software will also recommend that the procedure will take a LONGER TIME and a suitable battery maintenance device is attached because BOTH ECM and TCM need updated software.
The software always looks for the version loaded into the modules and will recommend that a NEWER VERSION IS AVAILABLE and will pretty much demand that it be installed before the CLEAR ADAPTATIONS be started if older software is found.
IDS 118.5 is the LAST version and I'm sure SDD revert Legacy IDS is 118.5.
If you actually CLEARED ADAPTATIONS with WDS/IDS or SDD revert to legacy IDS then you will NOT need a 'reflash' of the TCM. (PERIOD,END OF DISCUSSION)
The CLEAR ADAPTATIONS will proceed without any updated software required.
The TCM will 'learn' the new adaptations over time but Jaguar did offer some guidelines to speed up the process.
It can also 'learn' bad habits if the guidelines are not followed.
Tom In Dallas/Plano
This link can be helpful to know more about your transmission, but beware that these guys are into fixing or replacing the valve body even for simple things- it is like an obsessions with them. In my case I spoke to them as someone, thinking they were doing me a favor, had erased by TCM adaptions and I was having some difficulty getting them back.
So read with that caution in mind, but still great info that could find you some solution and give you a better understanding of your transmission.
https://www.bavlogic.com/?p=3738
You can also reach out to ZF as I did and they gave me the exact same advice as Brutal did.
I wrote them originally at passcarinfo@zf.com and thereafter all emails were from zfservicedesk@zf.com. I would send to both your exact symptoms.
Their NA phone number, where I talked to their service desk is ZF Services North America, LLC., telephone: 847 478 6868.
Give them details and they will have a reasonably good direction for you. They are happy to help.
Tom in Dallas/Plano
05 S-Type 3.0 123K
Based on your description of the original gripe....were you unaware you could just hold it in 4 for the first few miles until the xmsn fluid is warmed up?
Then the glitch that they relabeled a "feature" is defeated.
BlackKat
Dec 30, 2024 11:34 AM
Jpetreeko
May 20, 2011 07:14 AM
