Idle rpm
Thank you for your answers. Mine is at about 750 which I think is a little higher then normal.The reason I ask is because I have experienced "the lurch", and have noticed that on lower rpm the smother "the lurch".Is there a way I could lower the rpm myself? Or should I just try a software reflesh? Thank you in advance.
P.S. I remember my 2000 stype was idling at between 600-650.
Don't reflash, at least not any time soon. Use OBD live data to check LTFTs (see my sig) at idle and at 2500rpm to see if you may have a small air leak, which would raise idle rpm.
