Idle rpm
Old Nov 26, 2012 | 09:14 PM
coki80's Avatar
Default Idle rpm
Hello everyone.
Does anyone know the normal idle rpm on a 2003 s-type 3.0 engine? Thanks in advance.
Old Nov 27, 2012 | 04:53 AM
JagV8's Avatar
I'd guess (!) about 650.
Old Nov 27, 2012 | 05:11 AM
jimgoose's Avatar
Mine idles at ~850.
Old Nov 28, 2012 | 10:54 AM
coki80's Avatar
Thank you for your answers. Mine is at about 750 which I think is a little higher then normal.The reason I ask is because I have experienced "the lurch", and have noticed that on lower rpm the smother "the lurch".Is there a way I could lower the rpm myself? Or should I just try a software reflesh? Thank you in advance.
P.S. I remember my 2000 stype was idling at between 600-650.
Old Nov 28, 2012 | 11:05 AM
bfsgross's Avatar
The 3.0 should idle at 700 rpm.
Old Nov 28, 2012 | 11:10 AM
JagV8's Avatar
Don't reflash, at least not any time soon. Use OBD live data to check LTFTs (see my sig) at idle and at 2500rpm to see if you may have a small air leak, which would raise idle rpm.
Old Nov 28, 2012 | 02:43 PM
coki80's Avatar
Thank you for your advice. Will try that when I get home.
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
