I'm new to this
Old Aug 2, 2014 | 09:32 AM
ace1128's Avatar
Question I'm new to this
Hi I'm Paul have 3L s type auto jag my reverse won't work will rev up all other gears work is there a easy fix or is it garage and if any one would no roughly how much would cost to fix any help much appreciate thank u
Old Aug 2, 2014 | 10:14 AM
Mikey's Avatar
Always state the model year of your car when looking for assistance. The transmissions in pre- and post-face lift cars are very different.
Your problem might be a simple cable adjustment.
Old Aug 2, 2014 | 10:15 AM
abonano's Avatar
What year car are you talking about? Then we can go from there as there could be many causes depending on model year - from simple (shift cable) to horrible (Trans rebuild)
Old Aug 2, 2014 | 10:21 AM
ace1128's Avatar
Default Auto
2000 s type v6 w plate
Old Aug 2, 2014 | 10:59 AM
abonano's Avatar
OK - your shift cable could be stretched - can be adjusted from the shifter - search how to adjust it here on the forum or get JTIS. Otherwise, could be a solenoid issue - which would require a competent transmission shop. Stay away from Ammco, etc.
This is a common Ford 5 speed transmission (5R55N)
Has the fluid/filter ever been changed that you know of? If the answer is "no" or "I don't know" this should be a given as well, even if the shift cable is the cause of your no reverse issue...
Old Aug 2, 2014 | 11:12 AM
ace1128's Avatar
Smile
Thank u I'll look now much appreciate it
Old Aug 2, 2014 | 11:34 AM
JagV8's Avatar
Not really a job for a Jag dealer - it'll be expensive and they may well just get an autobox firm to do it, so you may as well go direct.
Old Aug 2, 2014 | 07:26 PM
NBCat's Avatar
Have you checked the fluid level via the procedure outlined in the JTIS?
If the fluid level is normal and the shift cable is secure, there is likely an internal fault with the valve body or the solenoids requiring disassembly and inspection.
A shop specialising in automatic gearboxes can likely provide an estimate should an overhaul be necessary.
Old Aug 3, 2014 | 05:09 AM
ace1128's Avatar
Smile Thanks
Thanks every one for ur help love my jag and want to keep it gd to pass down to my son as every man should own a jag once in his life and fall in love with driven again
Old Aug 3, 2014 | 09:04 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
When posting, please add some punctuation and spacing to make your posts more readable.
