Jacking Points??
Old Mar 26, 2009 | 09:01 PM
Oldengineer's Avatar
Default Jacking Points??
I own a pair of 3 ton hydraulic trolley jacks. Are there safe jacking points under the S where I can use these things?? I don't want to bend something expensive underneath while doing an oil change or rotating tires. Mine's an 06 4.2 model.
Regards:
Oldengineer
Old Mar 26, 2009 | 11:30 PM
joycesjag's Avatar
A double jacker hmmmm, I am an old fashion kind guy, I jack by the book.
Old Mar 27, 2009 | 04:22 AM
NvmyJag's Avatar
I had the same issue when jacking up my S-Type and I also like to use the jacking points so I made a wood block w/a slit in the middle to fit perfectly in the slot. I just slide the piece of wood in the slot and then put my jack under the wood and it's up in the air in seconds.
Old Mar 27, 2009 | 06:26 AM
Jon89's Avatar
Ditto that comment about wood - wood is your friend when jacking up any vehicle. I also lay a piece of rubber across the wood block as an extra measure of protection. Jacked up my S-Type earlier this week for a tire rotation and didn't have an issue using this tried-and-true system.
Old Mar 27, 2009 | 07:04 AM
joycesjag's Avatar
Jacking with wood, am I in the right forum? Do you guys prefer hardwood or softwood when jacking?
Old Mar 27, 2009 | 07:31 AM
Jon89's Avatar
Hey joycesjag,
From your recent posts I think you need to round up some of your buddies tonight and hit the strip clubs. Sounds like you're in dire need of a therapeutic session to see Jasmine, Jennifer, and Jade down at the local Pretty Palace....
Old Mar 27, 2009 | 08:04 AM
joycesjag's Avatar
Novel idea Jon. Wanna meet half way?
Old Mar 27, 2009 | 08:59 PM
Now that I'm over 60, I got the ones with the "quick up" feature as well.
Regards:
Oldengineer
Old Mar 27, 2009 | 09:22 PM
joycesjag's Avatar
John, you must have a look at my "thingy" post then. "If you experiance "quick ups" for more than a 4 hour period, PLEASE consult with your local Jaguar mechanic.
Old Mar 27, 2009 | 10:51 PM
I saw it - needed a good laugh today. Unfortunately I doubt if any of the local Jag mechanics can figure out how to get it down.
Regards:
Oldengineer
jagent
Jun 5, 2022 02:18 PM
magmedia
Aug 15, 2019 08:54 PM
mjm3457
Jan 30, 2018 09:02 AM
BSM
Sep 25, 2015 05:00 PM
Collector1
Sep 25, 2015 11:27 AM
