Jaguar s type 2005 4.2 v8 trouble codes pls help
Old Jan 17, 2022 | 10:11 PM
Stypebaby650's Avatar
Default Jaguar s type 2005 4.2 v8 trouble codes pls help
I have a Jaguar s type 2005 4.2 v8 with codes p0300 p0301 p0303 p0304 p0306 p1316 p1111 any help pls
Old Jan 18, 2022 | 02:29 AM
JagV8's Avatar
Get the codes PDF from here or JagRepair.com - Jaguar Repair Information Resource
Use Search for the codes to see what others were advised or did.
Old Jan 18, 2022 | 06:35 AM
M-e-l-l-o-w's Avatar
You can also download the full official Jaguar workshop manual that will give you the pin point tests for the fault codes. Here is a link:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
P0300 is a missfire in several cylinders.
P030* is a missfire in cylinder No*.
P1316 is an emmisions warning because a missfire is detected.
P1111 just shows that the system check is complete. It does not indicate a fault.
I guess that the first thing to do is to make sure you are not out of fuel, the fuel gauge may not be working as it should!
Mellow
Old Jan 18, 2022 | 07:31 AM
Mellow
I had already changed ignition coils all 8 and spark plugs 8months ago and fuel injectors on bank 1 can it my fuel injectors on bank 2 now ???
Old Jan 18, 2022 | 08:05 AM
kr98664's Avatar
Originally Posted by Stypebaby650
I had already changed ignition coils all 8 and spark plugs 8months ago…
Were you getting the same codes before charging the coils?
Old Jan 18, 2022 | 09:48 AM
clubairth1's Avatar
Community Influencer
Were the codes cleared and then the car driven so we can tell if these are current or just old codes??
Do you actually have any problems or just these codes?
Old Jan 18, 2022 | 11:54 AM
4 months ago I had fuel injectors problems on bank 1 got it fix all 4. reseted the check engine light drove car everyday in till I/M readiness was ready all checks green p1111 popped up car been running fine purring the rite away up till now 5 months in check engine pops up can with all these codes listed above can it just be spark plugs and coils easy fix or my fuel injectors now on bank 2 ???
Old Jan 18, 2022 | 12:00 PM
Or can it be that oil is going into my spark plugs witch is making it throw those codes or my O rings Valve covers gaskets??? Car doesn’t idle engine feels smooth the purr is a little different
Old Jan 19, 2022 | 12:01 AM
kr98664's Avatar
Or can it be that oil is going into my spark plugs…
It is possible, and easy enough to rule out. Oil can collect in the spark plug wells.
Pull the suspect coils and see if they need cleaning. Use an aerosol electronic cleaner, not brake cleaner. Only in the worst cases would the coils need to be replaced.
If you do find oil but don’t have time to replace the offending gaskets right away, you can usually buy some time with a good cleaning. Unless you’ve got an absolute gusher of an oil leak (not likely), you’ll have plenty of time to order gaskets and plan ahead for the job.
Old Jan 27, 2022 | 10:23 AM
Did you fit the correct NGK spark plugs and a good known make of coil pack? (ie not a cheap ones?)
Mellow
middlemarsh
Mar 26, 2017 12:09 PM
ianmj
Sep 3, 2016 04:43 PM
DaimlerMK2
Jul 30, 2013 12:44 PM
fatty
Jan 11, 2012 06:06 AM
John Mac
Apr 24, 2009 11:29 AM
