Jaguar s type 3.0 v6 manual 2000
Old Nov 13, 2014 | 07:18 AM
middlemarsh's Avatar
Default Jaguar s type 3.0 v6 manual 2000
I bought a Jaguar s type 3.0lt V6 manual in March this year.Amongst a few other jobs i had to replace the power steering pump everything worked untill now that is has become colder the pump makes an awfull noise when its cold but as it warms up it becomes silent.Now i wonder if i have put the correct steering fluid in it? I have just found out that i have put a mineral type in it and not a synthetic does anyone know if i replace it with synthetic fluid will it cure the problem? And if i don't replace it will it damage the pump?
Old Nov 13, 2014 | 07:20 AM
Just checked again and it is definately the pump making the noise.Strange this has only just started to happen as the weather has got colder.
Old Nov 13, 2014 | 07:28 AM
middlemarsh,
As you've already made a separate Intro, I've moved this question from New Member Area - Intro a MUST to S-Type forum.
This is the place to post technical questions about your S-Type. Members here with the same model will be able to help.
Old Nov 13, 2014 | 08:12 AM
joycesjag's Avatar
I am not an expert by any means. But by putting the incorrect fluid into the pump I can definitely see bad things happening. What do you have to loose by draining and refilling with the correct fluid as I see it.
Old Nov 13, 2014 | 09:42 AM
Mikey's Avatar
Car fluids are far more complex than just 'mineral' vs. 'synthetic'. Put the correct fluid in and hope that cures it.
Old Nov 13, 2014 | 12:30 PM
Thanks for the feedback guys just ordering some Dextron 111.Will try that.
Old Nov 14, 2014 | 03:44 AM
Paul792's Avatar
A long time member and many time Jaguar owner (Grant Francis) sent the post below for the early S type, to me, when I first became a member. I have not yet had to use his advice but I will in the future. I especially like the idea of draining with a syringe.
"the Power Steer fluid is "special" and I use Penrite PAS, whish is Green, and exactly the Spec for the Ford rack in our early cars. Mine had ATF when I got it, and steering was lousy/noisey/etc, and now after 4 syringe out and top off, is SWEET." (Grant Francis)
By mentioning this I am not arguing the point against using Dexron III simply because I have not had to do this job yet. But his advice is noteworthy.
Old Nov 14, 2014 | 04:54 AM
tony1963's Avatar
I doubt that Dexron III is going to be an acceptable steering fluid. That's older Mercedes and domestic cars. However, do the right thing and use the proper fluid.
Old Nov 14, 2014 | 05:48 AM
JagV8's Avatar
The spec is in the stickies.
Old Nov 14, 2014 | 10:03 AM
Mikey's Avatar
Dexron III is the correct fluid as per the owners manual................
Old Nov 14, 2014 | 11:30 AM
joycesjag's Avatar
Does it state US quarts or litres?
Old Nov 14, 2014 | 12:15 PM
Mikey's Avatar
Most alarmingly, not only does it not specify units of measure, it makes no mention of system volume at all. The only guidance is "Check that the fluid level is between the marks on the dipstick. If necessary, top up with power steering fluid as specified by your Jaguar Dealer." followed by "Should the level be very low, report the loss of fluid to the nearest Jaguar Dealer."
As I see it, there is distinct ambiguity of what constitutes 'very low' where the action of the owner goes from following the top up procedure as specified by your dealer to the more extreme reporting the loss to the nearest dealer.
I was always taught that any sort of serious loss should be reported to the police, followed by the insurance people.
I'm so confused.
Old Nov 14, 2014 | 01:27 PM
tony1963's Avatar
7 quarts?
Old Nov 14, 2014 | 03:18 PM
JagV8's Avatar
The (total) fill capacity is also in the stickies but you fill it as described.
sadepol01
16
Nov 22, 2024 05:05 PM
mikiep
Dec 20, 2019 07:37 PM
jorgef858
Jan 14, 2016 11:32 AM
Clare Jennings
Oct 4, 2015 05:43 PM
baskervillema
Oct 1, 2015 06:43 PM
