Jaguar S-type..Auto Gear lever Selection Problem
Old Sep 30, 2019 | 02:00 AM
GaryGGve's Avatar
Default Jaguar S-type..Auto Gear lever Selection Problem
My gear selector stopped being able to select lower gears and only 3rd could be selected. It now struggles to stay in 4th or D. If i push up harder it seems to improve the problem marginally.
Does anyone know the possible cause and how serious a problem it could be. Is likely to be a cable or internal transmission problem
model 1999
Thanks Gary
Old Oct 2, 2019 | 06:01 AM
JagV8's Avatar
A manual car?
Old Oct 2, 2019 | 10:56 AM
kr98664's Avatar
Originally Posted by JagV8
A manual car?
I think it's an auto because he mentioned the D position.
I'd suggest removing the console for a looksee:
https://www.jaguarforums.com/forum/s...install-93398/
Look for debris getting in the way of the shift mechanism. If nothing obvious, disconnect the cable from the side of the shifter assembly. See if the shift lever still binds or if it operates smoothly.
If the shift lever operates smoothly with the cable disconnected, reconnect the cable at the top and disconnect it at the transmission. If the binding returns, the cable was likely at fault. Please note this last step is not 100% conclusive as the cable may be defective but operates smoothly without a load on it.
Rogelio Serrano
Dec 4, 2016 10:50 AM
Bcrary3
Apr 29, 2015 09:47 AM
Kane973
Feb 17, 2015 12:18 AM
dennisw
Sep 26, 2013 06:33 AM
