Jaguar S Type Gearbox Part Number (code)
Old Feb 28, 2015 | 06:02 AM
Comrade Gibby's Avatar
Thumbs up Jaguar S Type Gearbox Part Number (code)
Good afternoon Hon members. Does the part number or code on gearboxes matters if the jags are of the same genre? For instant Jaguar S Type 3000cc V6 2003 which is fitted with gearbox code number 2R 83 7000 GK can it be swapped with a gearbox code number 6R 83 7000 DD from Jaguar S Type 2005? Please help. Many thanks
Old Feb 28, 2015 | 09:27 AM
I would ask this question in S-Type tech forum for response and advice from around the World. Do you want me to move it for you?
Old Mar 1, 2015 | 08:13 AM
Please sir, do that for me I really appreciate that. Many thanks
Old Mar 1, 2015 | 08:29 AM
Moved to S-Type forum. Expiring re-direct left in UK & Eire forum.
(I've added this post to bump it to the top of the threads.)
Old Mar 1, 2015 | 08:54 AM
NBCat's Avatar
I believe from MY 2002.5 (MY 2003 in NA) on, S-Type cars were fitted with the ZF 6HP26 gearbox and may be interchangeable from year to year. Prior to that, all S-Type vehicles used the Ford 5R55N gearbox, which is a five-speed.
Look at the mounting points and other connectors to be certain.
Also, review the 'sticky' section for 'how-to' guides as there is one that pertains to servicing the gearboxes.
Old Mar 1, 2015 | 09:52 AM
Thanks very much sir for your help.
Old Mar 1, 2015 | 10:09 AM
Thus very true MY S TYPE is a late 2003 model and has a 6HP26 2R837000GK gearbox. But after my research, I'm very surprise to note that it uses the same torque converter with the s type 2005 6HP26 6R837000DD gearbox. I'm not sure if that is an indicator that they can be swapped
Old Mar 1, 2015 | 10:15 AM
Cambo's Avatar
2003 in the UK (Braintree in Essex, right?) means it's the 6-speed ZF transmission.
You will have to source a transmission from a 3.0L V6 model 2003 onwards.
You can't use the transmission from a V8 or Diesel because the bellhousing pattern is different...only from a 3.0L V6...
If you find a wrecked 3.0L X350 XJ the transmission would be the same also.
Either way you will have to have the TCM reprogrammed to suit the car.
Old Mar 1, 2015 | 10:54 AM
Thanks for your response sir. Its true my jaguar is an s type 3.0 v6 registered in 2003 UK and it uses a 6HP26 2R837000 GK gearbox. I want to fit on a 6HP26 6R837000 DD gearbox from an s type 3.0 v6 2005. So according to your advice I won't counter any problem if I go ahead fitting this gearbox, not so sir?
Old Mar 1, 2015 | 10:57 AM
Cambo's Avatar
There have been five part number revisions on the 6HP transmission to suit the 3.0L S-Type, each one is a "supercession" so it's backwards compatible. I cannot see how you would have a problem fitting the 2005 transmission to the 2003 model.
But you will have to get it reprogrammed to the car.
Old Mar 1, 2015 | 11:19 AM
Thanks very much for this advice sir. Does it cost much to reprogram the gearbox to a jag?
Old Mar 1, 2015 | 01:48 PM
Mikey's Avatar
To most members in North America, it's a city in the US state of Massachusetts. Very common to see towns and cities here that are named after a place in the UK or Europe. It helps when members fill their profiles out fully, taking this into account.
Malihide
Apr 11, 2026 02:58 PM
daro31
Aug 27, 2015 09:26 AM
innzane
Aug 26, 2015 08:41 PM
Terrance Williams
Aug 26, 2015 11:50 AM
